Timer Demo
Started by David Kenny, December 26, 2013, 06:53:29 AM
David Kenny
I threw this together to try and answer a question posted elsewhere.
It show three of many ways to use timers. A one-time timer to keep a splash screen up for three seconds, a timer to count seconds the entire time the main form is shown, and a timer that the user can start and stop, that also counts seconds. It demonstrates that once you start a timer, it will fire the event routine when the timer reaches zero. The timer automatically restarts withe the old interval and will start the countdown again.  It will only stop when the timer is killed.  While you can kill a timer anytime and anywhere in your program, the timer event is a good place to kill the timer or to change the interval (as well as anything you wanted to process at the end of the interval).
Hope it is of use to some of you.
David
Eddy Van Esch
Nice, David. Thanks for posting.
Eddy
Theo Gottwald
Global gUCTSeconds As Long
Function MAINFORM_WM_CREATE ( _
    SetTimer(hWndForm, IDC_MainForm_SplashScreenTmr, 3000)    'Set timer for three seconds
    SplashScreen_Show(hWndForm, %True)
Function MAINFORM_SPLASHSCREENTMR_WM_TIMER ( _
                                        wTimerID      As Dword  _  ' the timer identifier
  KillTimer(hWndForm,wTimerID)      'This makes sure the SplashScreen timer only happens once
  FF_CloseForm( HWND_SplashScreen )
  SetTimer( hWndForm, IDC_MainForm_SecondsTmr,1000 )  'Set the Seconds timer for 1 second intervals.
Function MAINFORM_SECONDSTMR_WM_TIMER ( _
                                      'We don't kill this one.... it counts down forever.
    Static Seconds As Long
    Incr Seconds
    FF_Control_SetText( HWND_MainForm_SecondsLbl, "Form active for" & Str$(Seconds) & " seconds." )
Function MAINFORM_STARTBTN_BN_CLICKED ( _
    gUCTSeconds = 0
    FF_Control_SetText( HWND_MainForm_UserControlledLbl, "" )
    SetTimer (hWndForm,IDC_MainForm_UserControlledTmr, 1000)   'Set the timer to 1 full second again
Function MAINFORM_STOPBTN_BN_CLICKED ( _
    KillTimer(hWndForm,IDC_MainForm_UserControlledTmr)
    FF_Control_SetText( HWND_MainForm_UserControlledLbl, "User controlled timer killed after" & Str$(gUCTSeconds) & " seconds." )
Function MAINFORM_USERCONTROLLEDTMR_WM_TIMER ( _
                                             'This timer interval is set to 1000 milliseconds(1 second) at design time in the timer properties.
                                             'It can be stopped and started by the user. The counter is reset when the user selects the Start button.
    Incr gUCTSeconds
    FF_Control_SetText( HWND_MainForm_UserControlledLbl, "User controlled timer active for" & Str$(gUCTSeconds) & " seconds." )
David Kenny
Hello Theo,
I am not sure what you are trying to show here?
