Allow only one instance of a program
Started by Petrus Vorster, February 18, 2015, 12:50:41 PM
Just a recap please.
How do you allow only one instance of your program to run?
-Regards
Peter
Jean-pierre Leroy
Hi Petrus,
Just put this code in the FF_WINMAIN special function:
If FF_PrevInstance Then
        Function = %True    'return %TRUE if you want the program to end.
        Exit Function
You can add a message to inform the end user as well.
Regards,
Jean-Pierre
-Regards
Peter
