Wrapper
Started by James Klutho, June 18, 2004, 12:24:32 AM
James Klutho
Paul- You might consider making another tab in your Workspace window and putting templates to your wrappers there so they are more handy to copy and paste than using the windows help file.  I can rarely remember the correct syntax so I do a lot of checking up.  Great work Paul.
Hi James,
Yes, right you are. That is something that is on my to-do list. It had been suggested previously by a beta tester. Actually, instead of an additional tab, i plan to make it a stand-alone popup window.  The list will also be categorized in order to make it easier for users to find the specific wrapper they need.
With ADO/ADOX support coming, the wrapper list count will grow into the hundreds.
John Fitz
Quote from: TechSupportActually, instead of an additional tab, i plan to make it a stand-alone popup window.  The list will also be categorized in order to make it easier for users to find the specific wrapper they need.
I think that is going to be a truly great feature. The wrapper functions are a quantum leap in FF and with a popup the ease of use is greatly enhanced.  :thumbsup:
JF
