%USEOBJECTFRAMEWORK
Started by Heinz Grandjean, August 14, 2015, 02:37:27 PM
Heinz Grandjean
Hello!
In CodeGen_MyApp_Main.bas  the following line (suddenly????) appears:
%USEOBJECTFRAMEWORK = %TRUE
#IF %DEF(%USEOBJECTFRAMEWORK)
   GLOBAL AppFormsClass AS iAppForms
#ENDIF
I get error: "UNDEFINED TYPE":  iAppForms
I think the Problem is the Definition-line.
That line doesn't appear in other apps built with FF 3.74.
I really don't know where to seek for the error.
Help would be appreciated.
Thank you,
Heinz Grandjean
Open your project file (Myapp.ffp) and search for the following line:
UseObjectFramework=0
Make sure that it is set to 0 and not 1.
The object framework has been removed from FireFly but I have not totally removed the code generation of some equates so if that setting is set to true in the project file then there could be problems.
Heinz Grandjean
Thank you, Paul.
Problem solved.
Heinz Grandjean
