FF_WRAP
Started by Paul Squires, August 19, 2015, 01:43:54 PM
''  FF_WRAP
''  Add paired characters to the beginning and end of a string.
''  It is particularly useful for enclosing text with parenthesess,
''  quotes, brackets, etc.
''  For example:  FF_Wrap("Paul", "<", ">") results in <Paul>
''  If only one wrap character/string is specified then that character
''  or string is used for both sides.
''  For example:  FF_Wrap("Paul", "'") results in 'Paul'
''  If no wrap character/string is specified then double quotes are used.
''  For example:  FF_Wrap("Paul") results in "Paul"
Function FF_Wrap Overload ( ByRef sMainString As String, _
                            ByRef sLeftChar   As String, _
                            ByRef sRightChar  As String _
                            ) As String
   Function = sLeftChar & sMainString & sRightChar
                            ByRef sLeftChar   As String = Chr(34) _
                            ) As String
   Function = sLeftChar & sMainString & sLeftChar
In my opinion, FF_Wrap provides a little more versatility than PB's version because you can use 1, 2, or 3 parameters.
