FF_SHRINK
Started by Paul Squires, August 19, 2015, 01:47:42 PM
''  FF_SHRINK
''  Shrink a string to use a consistent single character delimiter.
''  The purpose of this function is to create a string with consecutive
''  data items (words) separated by a consistent single character. This
''  makes it very straightforward to parse the results as needed.
''  If sMask is not defined then all leading spaces and trailing spaces
''  are removed entirely. All occurrences of two or more spaces are changed
''  to a single space. Therefore, the new string returned consists of zero
''  or more words, each separated by a single space character.
''  If sMask is specified, it defines one or more delimiter characters to
''  shrink. All leading and trailing mask characters are removed entirely.
''  All occurrences of one or more mask characters are replaced with the
''  first character of sMask. The new string returned consists of zero or
''  more words, each separated by the character found in the first position
''  of sMask.
''  WhiteSpace is generally defined as the four common non-printing
''  characters:  Space, Tab, Carriage-Return, and Line-Feed. sMask = Chr(32,9,13,10)
Function FF_Shrink( ByRef sMainString As String, _
                    ByRef sMask       As String = " " _
                    ) As String
    Dim nLen       As Integer = Len(sMask)
    Dim i          As Integer
    Dim z          As Integer
    Dim nStart     As Integer
    Dim sDuplicate As String
    Dim sReplace   As String  = Left(sMask, 1)
    Dim s          As String
    ' Eliminate all leading and trailing sMask characters
    s = Trim(sMainString, Any sMask)
    ' Eliminate all duplicate sMask characters within the string
    For z = 0 To nLen - 1
       sDuplicate = Chr(sMask[z]) & Chr(sMask[z])  ' usually double spaces
       i = 1
       Do
           i = Instr(s, sDuplicate)
           If i > 0 Then
              s = Left(s, i - 1) & sReplace & Mid(s, i + Len(sDuplicate))
       Loop Until i = 0
    Next
    ' Replace all single characters in the mask with the first character
    ' of the mask.
    i = 1
    Do
        i = Instr(i, s, Any sMask)
        If i > 0 Then
           ' only do the replace if the character at the position found is
           ' different than the character we need to replace it with. This saves
           ' us from having to do an unneeded string concatenation. Use pointer
           ' arithmetic (zero based) to make comparison faster.
           If s[i-1] <> sMask[0] Then
              s = Left(s, i - 1) & sReplace & Mid(s, i + 1)
           i = i + 1
    Loop Until i = 0
    ' Finally, do a pass to ensure that there are no duplicates of the
    ' first mask character because of the replacements in the step above.
    sDuplicate = Chr(sMask[0]) & Chr(sMask[0])
    i = 1
    Do
        If i > 0 Then
    Loop Until i = 0
    Return s
