Free Basic: Hello World with gradient (CWindow)
Started by José Roca, August 27, 2015, 11:56:06 AM
Notice that the instrinsic RGB function does not what we are used to see. The graddient procedure didn't work until I changed it to BGR. The Free Basic documentation warns that the C macro RGB has been renamed as BGR to avoid conflicts with the Free Basic RGB intrinsic function... But they should have chosen a less missleading name, don't you think? It does the opposite of what his name suggests.
' Microsoft Windows
' File: CW_HelloWordGradient_HDPI.pbtpl
' Contents: CWindow Hello Word with gradient example (High DPI)
' Copyright (c) 2015 Jose Roca. Freeware. Use at your own risk.
#define unicode
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
' Gradient fill procedure
SUB DrawGradient (BYVAL hDC AS HDC)
   DIM rcFill   AS RECT
   DIM rcClient AS RECT
   DIM fStep    AS SINGLE
   DIM hBrush   AS HBRUSH
   DIM lOnBand  AS LONG
   GetClientRect WindowFromDC(hDC), @rcClient
   fStep = rcClient.Bottom / 200
   FOR lOnBand = 0 TO 199
      SetRect @rcFill, 0, lOnBand * fStep, rcClient.Right + 1, (lOnBand + 1) * fStep
      ' // Note: The C macro RGB has been renamed as BGR to avoid conflicts with the Free Basic RGB intrinsic function
      hBrush = CreateSolidBrush(BGR(0, 0, (255 - lOnBand)))
      FillRect hDC, @rcFill, hBrush
      DeleteObject hBrush
' Window procedure
   DIM hDC AS HDC
   DIM pPaint AS PAINTSTRUCT
   DIM rc AS RECT
   DIM pWindow AS CWindow PTR
   FUNCTION = 0
   SELECT CASE AS CONST uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_PAINT
         ' // Draw the text
         hDC = BeginPaint(hwnd, @pPaint)
         GetClientRect hwnd, @rc
         SetBkMode hDC, TRANSPARENT
         SetTextColor hDC, &HFFFFFF
         DrawTextW hDC, "Hello, World!", -1, @rc, DT_SINGLELINE OR DT_CENTER OR DT_VCENTER
         EndPaint hwnd, @pPaint
         FUNCTION = TRUE
      CASE WM_ERASEBKGND
         ' // Draw the gradient
         hDC = CAST(HDC, wParam)
         DrawGradient hDC
         FUNCTION = TRUE
      CASE WM_SIZE
            ' // Resize the buttons
            pWindow = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
            pWindow->MoveWindow GetDlgItem(hwnd, IDOK), pWindow->ClientWidth - 185, pWindow->ClientHeight - 35, 75, 23, TRUE
            pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), pWindow->ClientWidth - 95, pWindow->ClientHeight - 35, 75, 23, TRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   pWindow.Create(NULL, "CWindow Hello World with gradient", @WndProc)
   pWindow.Brush = GetStockObject(WHITE_BRUSH)
   pWindow.Center
   ' // Add two buttons without position or size (they will be resized in the WM_SIZE message).
   pWindow.AddControl("Button", pWindow.hWindow, IDOK,     "&Ok")
   pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, "&Quit")
