Author Topic: Free Basic: Subclassed button (CWindow)  (Read 2668 times)
« on: August 27, 2015, 03:51:13 PM »
This example demonstrates how to add a subclassed button.
' Microsoft Windows
' File: CW_ButtonSubclass.fbtpl
' Contents: CWindow with a subclassed button
' Copyright (c) 2015 Jose Roca. Freeware. Use at your own risk.
#define unicode
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
' Window procedure
   DIM hDC AS HDC
   DIM pPaint AS PAINTSTRUCT
   DIM rc AS RECT
   DIM pWindow AS CWindow PTR
   FUNCTION = 0
   SELECT CASE AS CONST uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_SIZE
            ' // Resize the buttons
            pWindow = CAST(CWindow PTR, GetPropW(hwnd, "CWINDOWPTR"))
            pWindow->MoveWindow GetDlgItem(hwnd, IDCANCEL), pWindow->ClientWidth - 120, pWindow->ClientHeight - 50, 75, 23, TRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Processes messages for the subclassed Button window.
FUNCTION Button_SubclassProc ( _
   BYVAL hwnd   AS HWND, _                 ' // Control window handle
   BYVAL uMsg   AS UINT, _                 ' // Type of message
   BYVAL wParam AS WPARAM, _               ' // First message parameter
   BYVAL lParam AS LPARAM _                ' // Second message parameter
   ) AS LONG
   SELECT CASE uMsg
      CASE WM_DESTROY
         ' // REQUIRED: Remove control subclassing
         SetWindowLongPtrW hwnd, GWLP_WNDPROC, CAST(LONG_PTR, RemovePropW(hwnd, "OLDWNDPROC"))
   FUNCTION = CallWindowProcW(GetPropW(hwnd, "OLDWNDPROC"), hwnd, uMsg, wParam, lParam)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   pWindow.Create(NULL, "CWindow with a subclassed button", @WndProc)
   pWindow.Center
   ' // Add a button without position or size (it will be resized in the WM_SIZE message).
   pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, "&Close", 0, 0, 0, 0, 0, 0, 0, CAST(WNDPROC, @Button_SubclassProc))
« Last Edit: September 10, 2015, 12:10:23 AM by Jose Roca »
aloberr
  • Little Newbie
Re: Free Basic: Subclassed button (CWindow)
« Reply #1 on: January 23, 2016, 02:35:01 PM »
it look like your subclassing don't work , how can i subclass button click or static color to be simple?
« Reply #2 on: January 24, 2016, 07:56:04 AM »
What makes you thing that it doesn't work?
When processing the WM_GETDLGCODE you have to tell Windows which type of input you want to process:
   ) AS LONG
   SELECT CASE uMsg
      CASE WM_GETDLGCODE
         FUNCTION = DLGC_WANTALLKEYS
      CASE WM_LBUTTONDOWN
         ? "click"
      CASE WM_DESTROY
