Author Topic: CWindow: MDI Framework  (Read 2171 times)
« on: September 10, 2015, 08:26:18 AM »
A template to demonstrate CWindow's MDI support. To avoid bloat in applications that don't need it, I have wrapped all the MDI code in CWindod with #ifdef USEMDI. Therefore, to use it you have to add #define USEMDI before the #INCLUDEs.
' Microsoft Windows
' File: CW_MDI.pbtpl
' Contents: Template - CWindow MDI Framwwork (High DPI)
' Copyright (c) 2015 Jose Roca. Freeware. Use at your own risk.
#define unicode
#define USEMDI
#INCLUDE ONCE "windows.bi"
USING Afx.CWindowClass
' // Edit control identifier
#define IDC_EDIT 101
' // Menu identifiers
#define IDM_NEW      1001   ' New file
#define IDM_OPEN     1002   ' Open file...
#define IDM_SAVE     1003   ' Save file
#define IDM_SAVEAS   1004   ' Save file as...
#define IDM_EXIT     1005   ' Exit
#define IDM_UNDO     2001   ' Undo
#define IDM_CUT      2002   ' Cut
#define IDM_COPY     2003   ' Copy
#define IDM_PASTE    2004   ' Paste
#define IDM_TILEH    3001   ' Tile hosizontal
#define IDM_TILEV    3002   ' Tile vertical
#define IDM_CASCADE  3003   ' Cascade
#define IDM_ARRANGE  3004   ' Arrange icons
#define IDM_CLOSE    3005   ' Close
#define IDM_CLOSEALL 3006   ' Close all
' Build the menu
FUNCTION BuildMenu () AS HMENU
   DIM hMenu AS HMENU
   DIM hPopUpMenu AS HMENU
   hMenu = CreateMenu
   hPopUpMenu = CreatePopUpMenu
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&File"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_NEW, "&New" & CHR(9) & "Ctrl+N"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_OPEN, "&Open..." & CHR(9) & "Ctrl+O"
         AppendMenuW hPopUpMenu, MF_SEPARATOR, 0, ""
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVE, "&Save" & CHR(9) & "Ctrl+S"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_SAVEAS, "Save &As..."
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_EXIT, "E&xit" & CHR(9) & "Alt+F4"
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&Edit"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_UNDO, "&Undo" & CHR(9) & "Ctrl+Z"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CUT, "Cu&t" & CHR(9) & "Ctrl+X"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_COPY, "&Copy" & CHR(9) & "Ctrl+C"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_PASTE, "&Paste" & CHR(9) & "Ctrl+V"
      AppendMenuW hMenu, MF_POPUP OR MF_ENABLED, CAST(UINT_PTR, hPopUpMenu), "&Window"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_TILEH, "&Tile Horizontal"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_TILEV, "Tile &Vertical"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CASCADE, "Ca&scade"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_ARRANGE, "&Arrange &Icons"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CLOSE, "&Close" & CHR(9) & "Ctrl+F4"
         AppendMenuW hPopUpMenu, MF_ENABLED, IDM_CLOSEALL, "Close &All"
   FUNCTION = hMenu
' Default CWindow MDI callback function.
FUNCTION MDIWindowProc (BYVAL hwnd AS HWND, BYVAL uMsg AS UINT, BYVAL wParam AS WPARAM, BYVAL lParam AS LPARAM) AS LRESULT
   DIM hEdit AS HWND
   DIM rc AS RECT
   SELECT CASE uMsg
      CASE WM_CREATE
         ' // Retrieve a reference to the CWindow class from the main window handle
         DIM hRootOwner AS HWND = GetAncestor(hwnd, GA_ROOTOWNER)
         DIM pWindow AS CWindow PTR
         IF hRootOwner THEN pWindow = CAST(CWindow PTR, GetPropW(hRootOwner, "CWINDOWPTR"))
         ' // Create and edit control
         IF pWindow THEN
            GetClientRect hwnd, @rc
            pWindow->AddControl("Edit", hwnd, IDC_EDIT, "", 0, 0, rc.Right, rc.Bottom, _
               WS_CHILD OR WS_VISIBLE OR ES_MULTILINE OR WS_VSCROLL OR WS_HSCROLL OR ES_AUTOHSCROLL OR ES_AUTOVSCROLL OR ES_WANTRETURN OR ES_NOHIDESEL)
      CASE WM_MDIACTIVATE
         IF lParam = hwnd THEN
      CASE WM_SETFOCUS
         ' // Set the keyboard focus to the first control that is
         ' // visible, not disabled, and has the WS_TABSTOP style
         SetFocus GetNextDlgTabItem(hwnd, NULL, FALSE)
      CASE WM_SIZE
            ' // Resize the window and/or its controls
            hEdit = GetDlgItem(hwnd, IDC_EDIT)
            MoveWindow hEdit, 0, 0, LOWORD(lParam), HIWORD(lParam), TRUE
         ' Don't exit. Let DefMDIChildProc to process the message for
         ' properly resizing of the MDI child window.
      CASE WM_DESTROY
         ' // Do cleanup if needed, such removing properties attached
         ' // to the MDI child window.
   ' // The DefMDIChildProc function provides default processing for any window
   ' // message that the window procedure of a multiple-document interface (MDI)
   ' // child window does not process. A window message not processed by the window
   ' // procedure must be passed to the DefMDIChildProc function, not to the
   ' // DefWindowProc function.
   FUNCTION = DefMDIChildProc(hwnd, uMsg, wParam, lParam)
' Window procedure
   STATIC hwndClient AS HWND    ' // Handle of the MDI client window
   DIM hwndActive AS HWND       ' // Active window
   DIM ptnmhdr AS NMHDR PTR     ' // Information about a notification message
   DIM hMdi AS HWND             ' // MDI child window handle
   STATIC nIdx AS LONG          ' // Counter
   STATIC pWindow AS CWindow PTR
   FUNCTION = 0
   ' // Retrieve the MDI client window handle
   IF hwndClient = NULL AND pWindow <> NULL THEN hwndClient = pWindow->hwndClient
   SELECT CASE AS CONST uMsg
      CASE WM_CREATE
         ' // Retrieve a reference to the CWindow class from the CREATESTRUCT structure
         DIM pCreateStruct AS CREATESTRUCT PTR = CAST(CREATESTRUCT PTR, lParam)
         pWindow = CAST(CWindow PTR, pCreateStruct->lpCreateParams)
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
            ' // New window
            CASE IDM_NEW
               IF hwndClient THEN
                  nIdx += 1
                  DIM mdi AS MDICREATESTRUCTW, dwStyle AS DWORD
                  IF IsZoomed(CAST(HWND, SendMessageW(hwndClient, WM_MDIGETACTIVE, 0, 0))) THEN dwStyle = WS_MAXIMIZE
                  IF LOBYTE( GetVersion) < 4 THEN
                     mdi.szClass = CAST(LPCWSTR, @"FBFrameClass")
                     mdi.szTitle = NULL
                     mdi.hOwner  = CAST(HANDLE, GetWindowLongPtrW(hwndClient, GWLP_HINSTANCE))
                     mdi.x       = CW_USEDEFAULT
                     mdi.y       = CW_USEDEFAULT
                     mdi.cx      = CW_USEDEFAULT
                     mdi.cy      = CW_USEDEFAULT
                     mdi.Style   = dwStyle
                     hMdi = CAST(HWND, SendMessageW(hwndClient, WM_MDICREATE, 0, CAST(LPARAM, @mdi)))
                     hMdi = CreateWindowExW(WS_EX_MDICHILD OR WS_EX_CLIENTEDGE, _
                                     "FBFrameClass", _
                                     "", _
                                     dwStyle, _
                                     CW_USEDEFAULT, _
                                     CW_USEDEFAULT, _
                                     CW_USEDEFAULT, _
                                     CW_USEDEFAULT, _
                                     hwndClient, _
                                     NULL, _
                                     CAST(HANDLE, GetWindowLongPtrW(hwndClient, GWLP_HINSTANCE)), _
                                     NULL)
                  SetWindowTextW hMdi, "MDI Child Window " & STR(nIdx)
            ' // Tile horizontally
            CASE IDM_TILEH
               IF hwndClient THEN SendMessageW hwndClient, WM_MDITILE, MDITILE_HORIZONTAL, 0
            ' // Tile vertically
            CASE IDM_TILEV
               IF hwndClient THEN SendMessageW hwndClient, WM_MDITILE, MDITILE_VERTICAL, 0
            ' // Cascade windows
            CASE IDM_CASCADE
               IF hwndClient THEN SendMessageW hwndClient, WM_MDICASCADE, 0, 0
            ' // Arrange icons
            CASE IDM_ARRANGE
               IF hwndClient THEN SendMessageW hwndClient, WM_MDIICONARRANGE, 0, 0
            CASE IDM_CLOSE
               ' // Close the active window
               IF hwndClient THEN
                  hwndActive = CAST(HANDLE, SendMessageW(hwndClient, WM_MDIGETACTIVE, 0, 0))
                  IF SendMessageW(hwndActive, WM_QUERYENDSESSION, 0, 0) THEN
                     SendMessageW hwndClient, WM_MDIDESTROY, CAST(LPARAM, hwndActive), 0
            CASE IDM_CLOSEALL
               ' // Close all the MDI child windows
               IF hwndClient THEN
                  EnumChildWindows hwndClient, @CWindow_CloseEnumProc, 0
            ' // Exit the application
            CASE IDM_EXIT
         ' // Pass unprocessed messages to the active MDI child and then to DefFrameProc()
         hwndActive = CAST(HWND, SendMessageW(hwndClient, WM_MDIGETACTIVE, 0, 0))
         IF IsWindow(hwndActive) THEN SendMessageW hwndActive, WM_COMMAND, wParam, lParam
      CASE WM_NOTIFY
         ptnmhdr = CAST(NMHDR PTR, lParam)
'         SELECT CASE ptnmhdr->idFrom
'         END SELECT
         IF hwndClient THEN
            IF IsWindow(hwndActive) THEN SendMessageW hwndActive, WM_NOTIFY, wParam, lParam
      CASE WM_SIZE
         ' // If the window isn't minimized, resize it
            IF hwndClient <> NULL AND pWindow <> NULL THEN
               pWindow->MoveWindow hwndClient, 0, 0, pWindow->ClientWidth + 2, pWindow->ClientHeight + 2, TRUE
         ' // Note: This message is not passed to DefFrameProc when space
         ' // is being reserved in the client area of the MDI frame
         ' // or controls on the MDI frame are resizeable.
      CASE WM_CLOSE
         IF hwndClient THEN
            ' // Attempt to close all MDI child windows
            ' // If child windows are still open abort closing the application
            IF GetWindow(hwndClient, GW_CHILD) THEN EXIT FUNCTION
      CASE WM_QUERYENDSESSION
         IF hwndClient THEN
    CASE WM_DESTROY
         PostQuitMessage(0)
   IF hwndClient THEN
   ' // The DefFrameProc function provides default processing for any window
   ' // messages that the window procedure of a multiple-document interface (MDI)
   ' // frame window does not process. All window messages that are not explicitly
   ' // processed by the window procedure must be passed to the DefFrameProc
   ' // function, not the DefWindowProc function.
      FUNCTION = DefFrameProcW(hwnd, hwndClient, uMsg, wParam, lParam)
   ' // The DefWindowProc function calls the default window procedure to provide
   ' // default processing for any window messages that an application does not process.
   ' // This function ensures that every message is processed. DefWindowProc
   ' // is called with the same parameters received by the window procedure.
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   pWindow.Create(NULL, "MDI with CWindow", @WndProc)
   ' // Change the window style to avoid flicker
   pWindow.ClassStyle = CS_DBLCLKS
   ' // Set the client size
   pWindow.SetClientSize 650, 400
   ' // Center the window
   pWindow.Center
   ' // Create a menu
   DIM hMenu AS HMENU
   hMenu = BuildMenu
   SetMenu pWindow.hWindow, hMenu
   '// Create a MDI client child window
   DIM hwindowMenu AS HMENU
   hwindowMenu = GetSubMenu(hMenu, 2)
   pWindow.CreateMDIWindow(101, 0, 0, 0, 0, 0, 0, hwindowMenu, @MDIWindowProc)
« Last Edit: September 10, 2015, 10:49:28 PM by Jose Roca »
Re: CWindow: MDI Framework
« Reply #1 on: September 10, 2015, 01:10:34 PM »
Works perfectly. Although I never use MDI windows anymore in my applications I am sure that some people still do and this will be very useful for them.
« Reply #2 on: September 10, 2015, 11:12:27 PM »
I only have used MDI once, for my CSED editor. However, if you don't add support for it, somebody will say: But it has not support for MDI like <put here the name of some multi megabyte library>... :)
Some people asks for MDI, but when they see that it is hard stuff, they change of idea and use tabs. And if you're a DDTer then you have no choice, because DDT does not support MDI.
As probably nobody will use it, I have wrapped all the code with ifdefs to avoid bloat.
Anyway, this template explains with detail all the needed steps. I like to write commented templates because they are ready to use from a click of my editor. Great for quick examples or tests.
« Last Edit: September 10, 2015, 11:36:12 PM by Jose Roca »
