Callback functions
Started by Petrus Vorster, September 22, 2015, 04:46:16 PM
I have a little piece of code that runs perfectly in the Powerbasic compiler.
(I will later see if this will work in freebasic too)
A key line is in the callback function of a Label control.
   Select Case Cb.Msg
      Case %WM_ContextMenu : Dialog End hDlg
      Case %WM_Command
         Select Case Cb.Ctl
            Case %IDC_Label : SendMessage hDlg, %WM_NCLButtonDown, %HTCaption, ByVal %Null  ' force drag
Where do i go with this in Firefly? It simply drags the form by a label on it.
-Regards
Peter
Function FORM1_LABEL1_STN_CLICKED ( _
                                  idStaticControl  As Long   _  ' identifier of static control
   SendMessage hWndForm, %WM_NCLBUTTONDOWN, %HTCaption, ByVal %Null  ' force drag
Thanks, sometimes i just dont get the picture where to go with the code that runs in the compiler and where to put that in FF.
Thanks a million
-Regards
Peter
