ShowERRS - FreeBAsic Error and Warning Dispay Tool
Started by Barry Gordon, October 06, 2015, 07:44:05 PM
Barry Gordon
Dear All,
I would like to offer you a little utility (called ShowERRS) that I wrote several months ago (in FreeBasic of course) and that I use regularly and find very helpful.
It basically goes through the FreeBasic generated '?compilelog.txt' file and the various FireFly code files and collates and displays a more meaningful list of error and warnings messages.
So if you take the following code snippet as an example:-
Function FORM1_WM_CREATE ( hWndForm as HWnd, ByVal UserData as Integer ) as Integer
' The variables Test and Test 1 are not defined so should give an error
Test = 1
Test1 = 1
' The function return is not defined so should give a warning
Then ShowERRS will generate a window containing the following information and also create a similar text file called ShowERRS.TXT in the RELEASE directory  (see FB1.JPG attached):-
Processing:  D:\Programming\FreeBasic\BarryFreebasicProjects\Project1\release\_Project1_compilelog.txt
D:\Programming\FreeBasic\BarryFreebasicProjects\Project1\release\CODEGEN_PROJECT1_FORM1_FORM.inc
Line: 624 - 'error 41: Variable not declared, Test in 'Test = 1''
623: '
624: Test = 1
625: Test1 = 1
626: '
Line: 625 - 'error 41: Variable not declared, Test1 in 'Test1 = 1''
624: Test = 1
625: Test1 = 1
626: '
627: ' The function return is not defined so should give a warning
Line: 629 - 'warning 13(0): Function result was not explicitly set'
628: '
629: End Function
630:
Completed ...
If you wish to use this tool then the program .EXE file is attached below in Zip compressed format.    You should decompress the file and place the .EXE in a suitable place.  I have a FreeBasic Tools directory in 'C:\Program Files (x86)\FreeBASIC Tools' and I store it there - but it can be stored anywhere as long as you tell the FireFly 'Tools' 'Edit User Tools' menu.   See attached FB2.JPG for a screenshot of how to set it up.  In the this screenshot - the line
'<R>_<P>_compilelog.txt 1 2 120'
is interpreted to mean:  display 1 line of code before the error line, 2 lines of code after the error line and truncate the ShowERRS.TXT file lines at 120 characters wide.  If the latter is set to 0 then the file will not be truncated.  You can set these parameters to whatever you want.   It is also set so that CTRL-L initiates the display.
I currently use the 32 bit version of FreeBasic - so ShowERRS may need a bit of tweaking to support the 64 bit - but I am happy to sort that out.
I hope somebody finds it useful - any positive feedback is always welcome.
Regards
Barry
Thanks Barry! Ever since you shared this tool with me a few weeks ago I use it almost daily. It is very useful and I encourage all new FireFly FreeBASIC users to try it out.
