Author Topic: Missing FRMFOO_Show() function  (Read 1630 times)
Andrew Lindsay
« on: January 10, 2016, 05:15:07 PM »
With the FreeBasic Version, how do I show another form?
In the PB Version, for form FOO, it was just FRMFOO_Show (), but I get an error saying that Variable FRMFOO_Show is not defined.
Or is there a different way to do things with FireflyFB?
Regards
Andrew
Re: Missing FRMFOO_Show() function
« Reply #1 on: January 10, 2016, 07:06:43 PM »
Hi Andrew,
Both versions work exactly the same way when displaying a form.
Function FRMFOO_Show( ByVal hWndParent As HWND, _
                             ByVal ShowModalFlag As Long, _
                             ByVal UserData As Long = 0 _
                             )  As HWND
Check your generated code to see if the function is generated.
Andrew Lindsay
« Reply #2 on: January 11, 2016, 03:53:28 PM »
Thanks Paul, late nights, plus a shift to night shift haven't helped the old cognitive skills.
It was there, I was just unable to spell the form correctly, then when I did spell the form correctly, I forgot about not needing the % for TRUE instead of %TRUE as in PB.
Regards
Andrew
