Author Topic: Using DisLin with FreeBasic and FireFly  (Read 1480 times)
Andrew Lindsay
« on: January 12, 2016, 06:45:22 PM »
Has anyone here had any experience with using the DisLin library for graphs and graphics?
I'm looking to see how easy it is to try to get some simple charting results up and running.  I'm unable to download the DisLin package onto my work computer as it is only available through FTP.
So it's all theoretical at the moment.  But any people with experience I would be interested in chatting with.
Best regards
Andrew
Eddy Van Esch
    • DevOTechS
Re: Using DisLin with FreeBasic and FireFly
« Reply #1 on: January 12, 2016, 06:52:21 PM »
Interesting, Andrew. Never heard of it before though, so can't help you.
What I have used before is GnuPlot.
This might be useful if the project is for your own use only.
Not suited for ' production purposes' .
http://www.powerbasic.com/support/pbforums/showthread.php?t=52573&highlight=gnuplot
Kind regards
Eddy
Eddy
« Reply #2 on: January 13, 2016, 07:20:44 AM »
There are some posts in the FreeBasic forum:
http://www.freebasic.net/forum/viewtopic.php?f=14&t=23984
