ZeeGrid a new and free grid available for PowerBASIC and Firefly users
Started by Jean-pierre Leroy, April 04, 2016, 06:30:37 AM
lol!  Well, I guess I will have to continue writing the grid after all.  :)
Jean-pierre Leroy
Quote from: Jose Roca on April 17, 2016, 07:50:16 PM
> How do you translate this line of code in PowerBASIC (my question is on the Cast operator) ?
You can't. You have to fill a variable and pass the address of the string text (VARPTR for ASCIIZ, STRPTR for STRING)
Jose, thank you for your answer.
Jean-pierre Leroy
Quote from: Jose Roca on April 17, 2016, 08:00:16 PM
Sorry, but I'm not going to use it. I have made a test and isn't adequate for High DPI applications.
@Jose : Thank you for the test.
@Jose, @Paul
I will create another thread about yet another grid called Simple Grid (32 bits, 64 bits, Unicode and C source code available).
I've compiled the source with PellesC and created the 32 bits and 64 bits DLL (they are not available on CodeProject.com).
More info about Simple Grid : http://www.codeproject.com/Articles/681771/Simple-Grid-A-Win-message-based-grid-control
I hope Simple Grid will be High DPI aware.
Jean-pierre Leroy
Quote from: TechSupport on April 17, 2016, 12:55:28 PM
Attached is a simple FreeBasic FireFly project showing a demo of the grid.
David sent me a 64 bits version of the DLL for test; I swith your FireFly for FreeBASIC demo project to 64 bits.
I get this error message when I try to compile the project.
Any ideas how to solve it ?
Change
CAST(HMENU, IDC_FRMMAIN_ZEEGRID)
to
CAST(HMENU, CAST(LONG_PTR, IDC_FRMMAIN_ZEEGRID))
If you're going to use FreeBasic, learn how CAST works, because you're going to have to use it more often that any other FB function.
Jean-pierre Leroy
Quote from: Jose Roca on April 19, 2016, 11:34:50 AM
If you're goign to use FreeBasic, learn how CAST works, because you're going to have to use it more often that any other FB function.
@Jose, thank you for your help; it works now. And yes I will probably use more and more often FireFly for FreeBASIC. I will learn how to use CAST. I promise you.
@Paul,  in this specific case the code in the FRMMAIN_ZEEGRID_INIT handler is generated directly by FireFly ... so I think that you should adapt this code (if possible) depending on the mode 32 bits and/or 64 bits. Is-it possible ?
Jean-pierre Leroy
Quote from: Jose Roca on April 17, 2016, 11:58:25 AM
But apparently it's only 32-bit, isn't it?
@Jose: As mentioned earlier, David sent me a 64 bits version of the DLL for test. I use it with FireFly for FreeBASIC 64 bits ... and so far so good.
Quote from: Jean-pierre Leroy on April 19, 2016, 12:51:37 PM
Thanks Jean-Pierre, I have now corrected the code generation for Custom Controls to eliminate this compile error. The code is the same for both 32 and 64 bits.
Jean-pierre Leroy
David Hillard has officially released a 64 bits version of his grid ZeeGrid.
Announcement on his website:
http://www.kycsepp.com/ZeeGrid_Docs/zeegrid_build_37.html
James Fuller
One item I found missing is a combo box cell.
I used the old FarPoint Spread DLL (2.5/3.0) as my primary data input device with PowerBASIC back in my contracting days and most of the data forms I designed had at at least one static data item that the user selected via a cell combo box.
James
Jean-pierre Leroy
James,
I will take a look at FarPoint Spread DLL (2.5/3.0).
Regarding ZeeGrid it is possible to set a combo box at the cell level; there is a notification message called %ZGN_LOADCOMBO that allow to do that at cell level;you can have a look at the screenshot below.
James Fuller
Is it possible to do this with zeegrid?
This uses the row number col as a label to what is wanted in a one col grid.
James
Jean-pierre Leroy
Quote from: James Fuller on April 21, 2016, 08:54:12 AM
James
I will try to do this kind of Grid with ZeeGrid; at least it is possible with MLG (MyLittleGrid) :
