First COM attempt: IFileOpenDialog
Started by José Roca, April 06, 2016, 02:13:57 PM
' Microsoft Windows
' File: CW_IFileOpenDialog.fbtpl - Template
' Contents: Demonstrates the use of the IFileOpenDialog interface.
#define unicode
#define _WIN32_WINNT &h0602
#INCLUDE ONCE "windows.bi"
#INCLUDE ONCE "win/shobjidl.bi"
USING Afx.CWindowClass
CONST IDC_OFD = 1001
' Displays the FileOpenDialog.
' The returned pointer must be freed with CoTaskMemFree
FUNCTION AfxIFileOpenDialogW (BYVAL hwndOwner AS HWND) AS WSTRING PTR
   DIM hr AS LONG
   DIM CLSID_FileOpenDialog AS CLSID = (&hDC1C5A9C, &hE88A, &h4DDE, {&hA5, &hA1, &h60, &hF8, &h2A, &h20, &hAE, &hF7})
   DIM IID_IFileOpenDialog AS GUID   = (&hD57C7288, &hD4AD, &h4768, {&hBE, &h02, &h9D, &h96, &h95, &h32, &hD9, &h60})
   ' // Create an instance of the FileOpenDialog object
   DIM pofd AS IFileOpenDialog PTR
   hr = CoCreateInstance(@CLSID_FileOpenDialog, NULL, CLSCTX_INPROC_SERVER, @IID_IFileOpenDialog, @pofd)
   IF pofd = NULL THEN RETURN NULL
   ' // Set the file types
   DIM rgFileTypes(1 TO 3) AS COMDLG_FILTERSPEC
   rgFileTypes(1).pszName = @WSTR("PB code files")
   rgFileTypes(2).pszName = @WSTR("Executable files")
   rgFileTypes(3).pszName = @WSTR("All files")
   rgFileTypes(1).pszSpec = @WSTR("*.bas;*.inc")
   rgFileTypes(2).pszSpec = @WSTR("*.exe;*.dll")
   rgFileTypes(3).pszSpec = @WSTR("*.*")
   pofd->lpVtbl->SetFileTypes(pofd, 3, @rgFileTypes(1))
   ' // Set the title of the dialog
   hr = pofd->lpVtbl->SetTitle(pofd, "A Single-Selection Dialog")
   ' // Display the dialog
   hr = pofd->lpVtbl->Show(pofd, hwndOwner)
   ' // Get the result
   DIM pItem AS IShellItem PTR
   DIM pwszName AS WSTRING PTR
   IF SUCCEEDED(hr) THEN
      hr = pofd->lpVtbl->GetResult(pofd, @pItem)
         hr = pItem->lpVtbl->GetDisplayName(pItem, SIGDN_FILESYSPATH, @pwszName)
         FUNCTION = pwszName
   ' // Cleanup
   IF pItem THEN pItem->lpVtbl->Release(pItem)
   IF pofd THEN pofd->lpVtbl->Release(pofd)
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
            CASE IDC_OFD
                  ' // Display the Open File Dialog
                  DIM pwszName AS WSTRING PTR = AfxIFileOpenDialogW(hwnd)
                  ' // Display the name of the selected file
                  IF pwszName THEN
                     MessageBoxW(hwnd, *pwszName, "IFileOpenDialog", MB_OK)
                     CoTaskMemFree pwszName
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Initialize the COM library
   CoInitialize(NULL)
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "IFileOpenDialog example", @WndProc)
   pWindow.Center
   ' // Add a button
   pWindow.AddControl("Button", pWindow.hWindow, IDC_OFD, "&Open File Dialog", 350, 250, 110, 23)
   ' // Process event messages
   ' // Uninitialize the COM library
   CoUninitialize
#2
It is like coming back to the times of PowerBASIC 6.1.
Fortunately I did learn COM programming the hard way and know how to work with it at low level.
Dominic will be happy with this compiler, because he likes to program this way.
aloberr
good work josé
I tried to convert your OLECON;inc to Freebasic and for now this work for some activex  and fails for another.
perhaps it is not good to post it for the moment?
Post it here if you want and I will look at it.
aloberr
Too big to post the source code, but have you tried to zip it as post it as an attachment?
Can't connect with
http://www.2shared.com/file/_SRYrFCZ/OLECON.html
at this moment. It time-outs.
I finally have been able to download it.
aloberr
#8
Sorry , one thing is that you need some modified headers.
here the grinding of FREEBASIC 1.05.0 containing the .bi files modified to also take into account the virtual classes
It is necessary to remind that these are only the files contained in the Win folder which are concerned.
The remainder without chagement.
A possibility is to rename the folder Freebasic/inc/win in your installation by Freebasic/inc/win_ and to copy my folder win in Freebasic/inc/
test your old projects, they will have to work.
if you have a project using the vtbl, it will be necessary to add in any beginning  #define _ FB_COM_VTBL _
http://www.2shared.com/file/11E5di-_/win.html
some examples to test: http://www.2shared.com/file/eJYl-WIo/test_project.html
Can you tell me which ones work and which ones fail?
Be aware that some VB OCXs never have worked fine with my OLE container.
For example, the FlexGrid and the MSHFlexGrid worked, but the DataGrid one don't.
aloberr
yes Jose, but there is still work to make with the FREEBASIC version
here is an example of use of msflxgrid
testolecon_reg.exe has a bug while clicking on the header of the grid
whereas testolecon_notreg.exe functions correctly
http://www.2shared.com/file/sG_EmGhc/msflexgrid_test.html
James Fuller
Jose,
  What is your position of COM with FreeBasic?
#1- I am working on my own approach.
#2- I am trying to adapt and use some/all of aloberr's code.
#3- Not interested.
James
I think that I'm going to use low-lewel COM and some helper functions. After all, now that the old VB OCXs are obsolete, we almost only need Automation to work with Office, and I don't use it.
Everything else that I have tried is not fully satisfactory. There is always the problem of freeing the temporary variables.
James Fuller
Jose,
  I just noticed this example is for Win8+.
I thought you were running Win7?
Is it possible to target Win7 +
James
What makes you think that it is for Windows 8? I'm using Windows 7.
