Author Topic: CWindow RC04  (Read 2848 times)
CWindow RC04
« on: May 02, 2016, 01:16:09 PM »
Cwindow release candidate 4.
Re: CWindow RC04 - Progress Bar Custom Control
« Reply #1 on: May 02, 2016, 01:25:06 PM »
I have adapted Börje's old PGBAR3D control using a class and make it DPI and unicode aware.
You can set the options using SendMessageW, the class methods or a mix of the two.
Example using SendMessage:
' Microsoft Windows
' File: CW_PG3D.fbtpl
' Contents: CWindow with a PGBAR3D control
#define unicode
#INCLUDE ONCE "windows.bi"
#INCLUDE ONCE "Afx/CPgBar3D.inc"
USING Afx.CWindowClass
USING Afx.CPgBar3DClass
enum
   IDC_START = 1001
   IDC_REVERSE
   IDC_OPTFAST
   IDC_OPTSLOW
   IDC_PGBAR1
   IDC_PGBAR2
   IDC_PGBAR3
end enum
' Window procedure
   STATIC slow AS LONG, allSteps AS LONG
   SELECT CASE uMsg
      CASE WM_CREATE
'      CASE WM_SYSCOMMAND
'         ' // Ignore the red X (close) button
'         IF (wParam AND &HFFF0) = SC_CLOSE THEN EXIT FUNCTION
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
            CASE IDC_OPTFAST
                  slow = FALSE
            CASE IDC_OPTSLOW
                  slow = CTRUE
            CASE IDC_START
               EnableWindow(GetDlgItem(hwnd, IDC_START), FALSE)   ' // Disable the start button
               SCOPE
               DIM i AS LONG, hCtl AS HWND, wszText AS WSTRING * 260
               FOR i = 1 TO 100
                  IF i < 34 THEN
                     hCtl = GetDlgItem(hwnd, IDC_PGBAR1)
                  ELSEIF i < 67 THEN
                     hCtl = GetDlgItem(hwnd, IDC_PGBAR2)
                     hCtl = GetDlgItem(hwnd, IDC_PGBAR3)
                  SendMessageW hCtl, PGB_STEPUP, 0, 0
                  wszText = WSTR(i) & "%"
                  SendMessageW GetDlgItem(hwnd, IDC_PGBAR2), PGB_SETTXTBKG, CAST(WPARAM, @wszText), CTRUE
                  SendMessageW GetDlgItem(hwnd, IDC_PGBAR2), PGB_SETTXTBAR, CAST(WPARAM, @wszText), CTRUE
                  IF i MOD 2 = 0 THEN AfxDoEvents(hwnd)
                  IF slow THEN SLEEP 40
               END SCOPE
               EnableWindow(GetDlgItem(hwnd, IDC_REVERSE), CTRUE)   ' // Enable the reverse button
            CASE IDC_REVERSE
               EnableWindow(GetDlgItem(hwnd, IDC_REVERSE), FALSE)   ' // Disable the reverse button
               SCOPE
               FOR i = 99 TO 0 STEP -1
                  IF i > 66 THEN
                  ELSEIF i > 33 THEN
                  SendMessageW hCtl, PGB_STEPDN, 0, 0
               END SCOPE
               EnableWindow(GetDlgItem(hwnd, IDC_START), CTRUE)   ' // Enable the start button
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "CWindow with PGBAR3D control", @WndProc)
   pWindow.SetClientSize(300, 155)
   pWindow.Center
   ' // Add the buttons
   DIM hbtReverse AS HWND = pWindow.AddControl("Button", pWindow.hWindow, IDC_REVERSE, "&Reverse", 30, 115, 100, 23)
   DIM hbtStart AS HWND = pWindow.AddControl("Button", pWindow.hWindow, IDC_START, "&Start", 168, 115, 100, 23)
   EnableWindow(hbtReverse, FALSE)   ' // Disable the reverse button
   ' // Add the check boxes
   pWindow.AddControl("Option", pWindow.hWindow, IDC_OPTFAST, "Fast", 30, 60, 75, 23)
   pWindow.AddControl("Option", pWindow.hWindow, IDC_OPTSLOW, "Slow", 30, 80, 75, 23)
   ' // Add a label
   DIM hLabel AS HWND = pWindow.AddControl("Label", pWindow.hWindow, -1, "", 29, 14, 242, 25, , WS_EX_CLIENTEDGE)
   ' // Add the first progress bar
   DIM pPgBar1 AS CPgBar3D = CPgBar3D(@pWindow, IDC_PGBAR1, "", 30, 15, 80, 23)
   SendMessageW pPgBar1.hWindow, PGB_SETMAX, 33, 0                           ' Max number of teps
   SendMessageW pPgBar1.hWindow, PGB_SETBARCOL, PGB_RED, 0                   ' Bar color scheme
   ' // Add the second progress bar
   DIM pPgBar2 AS CPgBar3D = CPgBar3D(@pWindow, IDC_PGBAR2, "", 110, 15, 80, 23)
   SendMessageW pPgBar2.hWindow, PGB_SETMAX, 33, 0                           ' Max number of teps
   SendMessageW pPgBar2.hWindow, PGB_SETBARCOL, PGB_GOLD, 0                  ' Bar color scheme
   SendMessageW pPgBar2.hWindow, PGB_SETTXTON, 0, PGB_TEXTCUSTOM             ' Show own text
   SendMessageW pPgBar2.hWindow, PGB_SETTXTCOLBKG, BGR(255, 255, 0), 0       ' Backgound text color yellow
   SendMessageW pPgBar2.hWindow, PGB_SETTXTCOLBAR, BGR(0, 0, 0), 0           ' Bar text color black
   ' // Add the third progress bar
   DIM pPgBar3 AS CPgBar3D = CPgBar3D(@pWindow, IDC_PGBAR3, "", 190, 15, 80, 23)
   SendMessageW pPgBar3.hWindow, PGB_SETMAX, 33, 0                           ' Max number of teps
   SendMessageW pPgBar3.hWindow, PGB_SETBARCOL, PGB_GREEN, 0                 ' Bar color scheme
   ' // Requires: Build the bars
   SendMessageW pPgBar1.hWindow, PGB_BUILDBARS, 0, 0
   SendMessageW pPgBar2.hWindow, PGB_BUILDBARS, 0, 0
   SendMessageW pPgBar3.hWindow, PGB_BUILDBARS, 0, 0
Example using the class methods:
' Microsoft Windows
#define unicode
enum
   IDC_START = 1001
   IDC_REVERSE
   IDC_OPTFAST
   IDC_OPTSLOW
   IDC_PGBAR1
   IDC_PGBAR2
   IDC_PGBAR3
end enum
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
            CASE IDCANCEL
            CASE IDC_OPTFAST
                  slow = FALSE
            CASE IDC_OPTSLOW
                  slow = CTRUE
            CASE IDC_START
               SCOPE
               DIM pPgBar1 AS CPgBar3D PTR = CAST(CPgBar3D PTR, GetPropW(GetDlgItem(hwnd, IDC_PGBAR1), "CPGBAR3DPTR"))
               DIM pPgBar2 AS CPgBar3D PTR = CAST(CPgBar3D PTR, GetPropW(GetDlgItem(hwnd, IDC_PGBAR2), "CPGBAR3DPTR"))
               DIM pPgBar3 AS CPgBar3D PTR = CAST(CPgBar3D PTR, GetPropW(GetDlgItem(hwnd, IDC_PGBAR3), "CPGBAR3DPTR"))
               FOR i = 1 TO 100
                  IF i < 34 THEN
                     pPgBar1->StepUp
                  ELSEIF i < 67 THEN
                     pPgBar2->StepUp
                     pPgBar3->StepUp
                  pPgBar2->SetBackText wszText, CTRUE
                  pPgBar2->SetBarText wszText, CTRUE
               END SCOPE
            CASE IDC_REVERSE
               SCOPE
                  IF i > 66 THEN
                     pPgBar3->StepDown
                  ELSEIF i > 33 THEN
                     pPgBar2->StepDown
                     pPgBar1->StepDown
               END SCOPE
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   pWindow.Center
   ' // Add a label
   pPgBar1.SetMaxSteps 33                                 ' Max number of teps
   pPgBar1.SetBarColor PGB_RED                            ' Bar color scheme
   pPgBar2.SetMaxSteps 33                                 ' Max number of teps
   pPgBar2.SetBarColor PGB_GOLD                           ' Bar color scheme
   pPgBar2.SetTextOn PGB_TEXTCUSTOM                       ' Show own text
   pPgBar2.SetBarTextColor BGR(255, 255, 0)               ' Backgound text color yellow
   pPgBar2.SetBarTextColor BGR(0, 0, 0)                   ' Bar text color black
   pPgBar3.SetMaxSteps 33                                 ' Max number of teps
   pPgBar3.SetBarColor PGB_GREEN                          ' Bar color scheme
   pPgBar1.BuildBar
   pPgBar2.BuildBar
   pPgBar3.BuildBar
James Fuller
Re: CWindow RC04
« Reply #2 on: May 02, 2016, 04:38:55 PM »
Jose,
  I noticed in your FBWThemes_HDPI_W7.xml no listing in the <!-- Compatibility section --> for Win 10.
Not needed?
James
Re: CWindow RC04
« Reply #3 on: May 02, 2016, 05:15:38 PM »
Jose,
Not needed?
James
Guess that it is needed, but I don't have Windows 10 to test.
Re: CWindow RC04
« Reply #4 on: May 02, 2016, 05:19:57 PM »
I have modified the Progress Bar slightly.
New code included in the attachment.
New examples also in the attachment.
Re: CWindow RC04
« Reply #5 on: May 02, 2016, 05:22:38 PM »
This control from Börje is a very nice replacement to the Windows progress bar control, that I found very ugly.
Re: CWindow RC04
« Reply #6 on: May 02, 2016, 05:38:53 PM »
I think that I'm going to store the pointer to the class in extra bytes of the window class instead of as a property.
