requested item
Started by James Fuller, May 28, 2016, 11:15:47 AM
James Fuller
Jose,
  Excellent work on your FreeBasic include files.
I am a bit out of practice but the one item I would like to see and did not find in the help file is a control layout operation. I've seen some of your PB code where you do it manually in the WM_SIZE event but this is way too tedious for any window with more than a coulple of controls.
Maybe Paul could adapt or add to cMaker to provide this capacity?
James
Dominic uses the Jeffrey Richter's layout algorithm, but I have been unable to find Richter's code.
I have found UILayout.h in a Chinese site, with comments in Chinese. I will try to adapt it to FreeBASIC.
James Fuller
Jose,
  Attached is an exe that uses the original "c" code compiled with the TDM-GCC-64 compiler. It has the same problem all approaches I have tried except one. I tried Patrice's code and it has the same issue. IUP is the only one I've found where frame text does not flicker
Most mail hosts whine on included exe's so I posted here.
Watch your email from my jcfuller22 gmail account for more info
James
Well, I have done the translation from the code found in the Chinese site.
This is the first test, with a button, that works fine. We may need to do more tests.
You will find the class in the attached .rar file.
' Microsoft Windows
' File: CW_LAYOUT_Button.fbtpl
' Contents: CWindow layout button example
#INCLUDE ONCE "windows.bi"
#INCLUDE ONCE "Afx/CUILayout.inc"
USING Afx.CWindowClass
USING Afx.CUILayoutClass
DIM SHARED g_UILayout AS CUILayout PTR
' Window procedure
   SELECT CASE uMsg
      CASE WM_CREATE
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_SIZE
         g_UILayout->AdjustControls(LOWORD(lParam), HIWORD(lParam))
    CASE WM_DESTROY
         PostQuitMessage(0)
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "CWindow with a button", @WndProc)
   pWindow.Center
   ' // Add a button
   pWindow.AddControl("Button", pWindow.hWindow, IDCANCEL, "&Close", 350, 250, 75, 23)
   g_UILayout = NEW CUILayout(pWindow.hWindow, 100, 100)
   g_UILayout->AnchorControl(AP_BOTTOMRIGHT, AP_BOTTOMRIGHT, IDCANCEL, FALSE)
   IF g_UILayout THEN Delete g_UILayout
James Fuller
Jose,
It's a no-go here compiled as 64bit on Win10
Compiles fine but nothing shows when run.
James
I dont have Windows 10 to test.
BTW the HandleMinMax procedure was missing, although I don't know what it is his purpose, because it is not used in the class.
James Fuller
#7
I tried the exe compiled on Win10 on a Win7 box and it failed there also.
I'm not set up to compile on Win7.
If I comment out the call in WM_SIZE the window shows.
James
Attached is the compiled test. It works in my computer with Windows 7.
James Fuller
Runs fine on Win7 does not on Win10.
James
There is nothing I can't do. As I said, I don't have Windows 10. You have the source code, try to find where it fails.
Quote from: Jose Roca on May 28, 2016, 05:19:34 PM
I have Windows 10. I will try to debug the problem now. I will report back soon.
Seems like the problem is with WM_SIZE. That message is sent during your window creation but of course the pointer has not been initialized until a short time later. When the second WM_SIZE arrives then the pointer is okay. It seems that the GPF occurs on the first null pointer during the first WM_SIZE. Just need to test for a null pointer I think.
      CASE WM_SIZE
         If g_UILayout Then
            g_UILayout->AdjustControls(Loword(lParam), Hiword(lParam))
         Exit Function
For some unknown reason, it doesn't GPF in my computer, when it should. Now the question is if it works in Windows 10 after adding the check or not.
It works for me on Windows 10 when I add the check. It GPF's when the check is omitted. Let's see if James experiences the same as I do.
