Author Topic: manifest  (Read 1302 times)
James Fuller
manifest
« on: June 21, 2016, 08:09:22 AM »
Jose,
This is what I am going to use for a manifest.
I noticed a difference in the asm3 dpiAware bewteen your Win7 and 8.1 /SMI/2005 vs /SMI/2011
I did some research but did not find any definitive answers.
Those I did find mentioning Windows 10 used /SMI/2005
I know you don't have Windows 10 but where did you find the Win7 vs Win 8.1 info??
James
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
   <assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0" xmlns:asmv3="urn:schemas-microsoft-com:asm.v3">
      <assemblyIdentity version="1.0.0.0"
         processorArchitecture="amd64"
         name="ApplicationName"
         type="win32"/>
      <description>Optional description of your application</description>
      <asmv3:application>
         <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2011/WindowsSettings">
            <dpiAware>true</dpiAware>
         </asmv3:windowsSettings>
      </asmv3:application>
      <!-- Compatibility section -->
      <compatibility xmlns="urn:schemas-microsoft-com:compatibility.v1">
         <application>
            <!--The ID below indicates application support for Windows Vista -->
            <supportedOS Id="{e2011457-1546-43c5-a5fe-008deee3d3f0}"/>
            <!--The ID below indicates application support for Windows 7 -->
            <supportedOS Id="{35138b9a-5d96-4fbd-8e2d-a2440225f93a}"/>
            <!--This Id value indicates the application supports Windows 8 functionality-->
            <supportedOS Id="{4a2f28e3-53b9-4441-ba9c-d69d4a4a6e38}"/>
            <!--This Id value indicates the application supports Windows 8.1 functionality-->
            <supportedOS Id="{1f676c76-80e1-4239-95bb-83d0f6d0da78}"/>
            <!-- This Id value indicates the application supports Windows 10 functionality-->
            <supportedOS Id="{8e0f7a12-bfb3-4fe8-b9a5-48fd50a15a9a}"/>
         </application>
       </compatibility>
      <!-- Trustinfo section -->
      <trustInfo xmlns="urn:schemas-microsoft-com:asm.v2">
         <security>
            <requestedPrivileges>
               <requestedExecutionLevel
                  level="asInvoker"
                  uiAccess="false"/>
               </requestedPrivileges>
         </security>
      </trustInfo>
      <dependency>
         <dependentAssembly>
            <assemblyIdentity
               type="win32"
               name="Microsoft.Windows.Common-Controls"
               version="6.0.0.0"
               publicKeyToken="6595b64144ccf1df"
               language="*" />
         </dependentAssembly>
      </dependency>
   </assembly>
James Fuller
Re: manifest
« Reply #1 on: June 21, 2016, 09:57:22 AM »
I just did some testing and I need SMI/2005 with the added Windows 10 listing.
James
  • Master Member
    • Jos
Re: manifest
« Reply #2 on: June 21, 2016, 11:36:42 AM »
Nowhere. I tried to update the manifest to add support for the new versions of Windows, copied some code found in MSDN and it did not work in Windows 7. I looked at the differences and noticed that the one that worked in my system had a 2005 and the one that don't a 2011.
  • Master Member
    • Jos
Re: manifest
« Reply #3 on: June 21, 2016, 11:53:00 AM »
James
Thanks for confirm it. Now I can reduce my manifest to two, with or without DPI support:
2
PBWIN
.xml
.Manifest (both 32 and 64 bit)
         processorArchitecture="*"
         type="win32"/>
         <application>
            <!--This Id value indicates the application supports Windows 10 functionality-->
         </application>
       </compatibility>
         <security>
                  level="asInvoker"
                  uiAccess="false"/>
         </security>
      </trustInfo>
      <dependency>
         <dependentAssembly>
            <assemblyIdentity
               type="win32"
               version="6.0.0.0"
               language="*" />
      </dependency>
   </assembly>
DPI aware:
2
PBWIN
.xml
.Manifest (both 32 and 64 bit) (High DPI)
         type="win32"/>
      <asmv3:application>
         <asmv3:windowsSettings xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">
         <application>
         </application>
       </compatibility>
         <security>
                  level="asInvoker"
                  uiAccess="false"/>
         </security>
      </trustInfo>
      <dependency>
         <dependentAssembly>
            <assemblyIdentity
               type="win32"
               version="6.0.0.0"
               language="*" />
      </dependency>
   </assembly>
