Author Topic: Font DPI  (Read 1007 times)
James Fuller
Font DPI
« on: June 21, 2016, 11:44:56 AM »
Jose,
  How does one create a dpi aware font?
The 3rd parameter of AfxCreateFont defaults to 96 according to the help file.
How do I create a font compatible with the actual dpi setting of the host.
I could not find a AfxGetDPI function which appears to be what I need???
James
James Fuller
Re: Font DPI
« Reply #1 on: June 21, 2016, 11:51:31 AM »
Duh...
I really should wait a bit before posting questions I am working on :) !!
James
Dim As CWindow pWindow
Dim As HFONT hInfoFont = AfxCreateFont("Tahoma",12,pWindow.DPI)
Re: Font DPI
« Reply #2 on: June 21, 2016, 12:06:15 PM »
You can also use
Dim As HFONT hInfoFont = pWindow.CreateFont("Tahoma",12)
Re: Font DPI
« Reply #3 on: June 21, 2016, 12:12:07 PM »
If you aren't using CWindow, you can use AfxLogPixelsX and or AfxLogPixelsY.
