WinFBE using CWindow #10
Started by Paul Squires, June 23, 2016, 10:58:19 PM
Latest source and binaries are attached. A fair amount of new functionality in this new release.
- Updated all code to replace literal value 255 with MAX_PATH.
- Change between 32 and 64 compiler easily by (1) Selecting it from the top menu; (2) Accelerator keys Ctrl+1, Ctrl+2; or (3) Clicking on the displayed compiler version in the first panel of the statusbar.
- frmGoto, frmFind, and frmReplace windows and code implemented.
Maybe something like that for gui and console?
Quote from: Jose Roca on June 24, 2016, 03:48:54 PM
That's a pretty good idea as well :)
....and probably another good one would be "debug" or "release".
There are some FB keywords, such sleep or inkey, that cause the program to hang if compiled as a gui by mistake. It would be nice if before compiling to gui, the editor will check if the program uses them and either ignore the gui option and compile it as a console application or display a warning message. Unfortunately there is not a compile gui or compile console metastatement.
This is now implemented. I will upload the new source tomorrow.
An small modification in modCBColor.inc:
'               RoundRect lpdis->hDC, rc.Left, rc.Top, rc.Right, rc.Bottom, AfxScaleY(3), AfxScaleY(3)
               RoundRect lpdis->hDC, rc.Left, rc.Top, rc.Right, rc.Bottom, pWindow->ScaleX(3), pWindow->ScaleY(3)
In frmOptions.inc add code to reflect the changes
      Case IDC_FRMOPTIONS_CMDOK
         If codeNotify = BN_CLICKED Then
            SaveEditorOptions()
            Dim pDoc As clsDocument Ptr = gTTabCtl.GetActiveDocumentPtr()   ' --> added code
            IF pDoc THEN pDoc->ApplyProperties   ' --> added code
            SendMessageW HWnd, WM_CLOSE, 0, 0
            Exit Function
Would also be nice to see if there are other files loaded in the editor and also apply the changed properties to them.
Quote from: Jose Roca on June 25, 2016, 03:35:19 PM
            SaveEditorOptions()
            Exit Function
Thanks Jose,
This is the code that added that will apply the properties to all loaded Scintilla windows.
            SaveEditorOptions()
            ' Apply the newly saved options to all open Scintilla windows
            Dim As Long nCount = gpApp->GetDocumentCount
            Dim As Long i
            For i = 0 To nCount - 1
               gpApp->GetDocumentPtr(i)->ApplyProperties
            Next
            Exit Function
The benefits of using that class is that the application is not fully Hight DPI aware (extremely important)
http://www.freebasic.net/forum/viewtopic.php?f=8&t=11533&p=221212#p221212
Be careful with the typos :)
LOL!  I meant to say "now" rather than "not". I edited the post and corrected it. Oops.
