Author Topic: Fb Object  (Read 1358 times)
James Fuller
Fb Object
« on: July 07, 2016, 10:37:10 AM »
Jose,
  Did you investigate Fb's Object?
If yes Opinions?
How about iterating operators?
James
« Last Edit: July 07, 2016, 10:39:24 AM by James Fuller »
Re: Fb Object
« Reply #1 on: July 07, 2016, 12:09:50 PM »
Not in deep. Pecking from flower to flower you achieve nothing. There will be time to explore it.
James Fuller
Re: Fb Object
« Reply #2 on: July 07, 2016, 01:39:34 PM »
I only mentioned Object as it appears to offer additional info if you base your classes on it with Extends?
James
Re: Fb Object
« Reply #3 on: July 07, 2016, 02:31:56 PM »
And also slows execution slightly. I have tried it in declares to COM servers to use abstract methods. This simplifies somewhat the syntax, e.g. instead of using pInterface->lpvtbl->MethodName(pInterface, <params>), you can use pInterface->Methodame(<params>). It is mandatory to use virtual methods, but I'm not a fan of OOP.
