CW_COMMCTRL_Edit
Started by James Fuller, August 24, 2016, 10:27:12 AM
James Fuller
Jose,
  In your CW_COMMCTRL_Edit demo when you first press the TAB key the caret moves to the EditMultiline control but nothing happens on subsequent presses.
James
This always have been the normal behavior of a multiline control, which controls the tab key, and others, because it has an option to set tab stops. If you want to change it, you need to subclass the control.
