CWindow RC 24
Started by José Roca, October 11, 2016, 10:11:34 PM
CWindow Release Candidate 24
I have removed many of the COM related stuff: CBSTR, CVARIANT, CSafeArray, CDispInvoke, CDicObj and the ADO classes.
I have added CWstrArray, that although internally uses a safe array of BSTRs, all the string parameters and return values are CWSTRs.
31.10.2016 : Updated with the latest version of CWSTR.inc
#1
I have also modified the TypeLib Browser to use CWSTR instead of CBSTR.
The adaptation of the Open and Save file dialog has been a little tricky. Only a C programmer can think of using embedded nulls as separators in a null terminated string... Crazy people! I could have used the COM API, but as Marc, the only user of this tool, is still working with XP...
Google Map example
' Microsoft Windows
' Contents: WebBrowser - Google map
#define UNICODE
#INCLUDE ONCE "Afx/CWebBrowser/CWebBrowser.inc"
USING Afx
CONST IDC_WEBBROWSER = 1001
' Build the script
FUNCTION BuildScript () AS STRING
   DIM s AS STRING
   s  = "<!DOCTYPE html>"
   s += "<html>"
   s += "   <head>"
   s += "      <meta http-equiv='X-UA-Compatible' content='IE=edge'>"
   s += "      <style>"
   s += "         html, body, #map-canvas"
   s += "         {"
   s += "            height: 100%;"
   s += "            margin: 0px;"
   s += "            padding: 0px"
   s += "         }"
   s += "      </style>"
   s += "      <script src='https://maps.googleapis.com/maps/api/js?v=3'></script>"
   s += "      <script>"
   s += "         var globalLatLng = '';"
   s += "         function initialize()"
   s += "         {"
   s += "            var mapOptions ="
   s += "            {"
   s += "               zoom: 8,"
   s += "               center: new google.maps.LatLng(51.5, -0.2),"
   s += "               mapTypeId: google.maps.MapTypeId.ROADMAP"
   s += "            };"
   s += "            var map = new google.maps.Map(document.getElementById('map-canvas'), mapOptions);"
   s += "         }"
   s += "         google.maps.event.addDomListener(window, 'load', initialize);"
   s += "      </script>"
   s += "   </head>"
   s += "   <body>"
   s += "      <div id='map-canvas'></div>"
   s += "   </body>"
   s += "</html>"
   FUNCTION = s
' Main
   ' // Set process DPI aware
   AfxSetProcessDPIAware
   ' // Creates the main window
   DIM pWindow AS CWindow
   DIM hwndMain AS HWND = pWindow.Create(NULL, "WebBrowser - Google map", @WndProc)
   pWindow.SetClientSize(750, 450)
   ' // Centers the window
   pWindow.Center
   ' // Add a WebBrowser control
   DIM pwb AS CWebBrowser = CWebBrowser(@pWindow, IDC_WEBBROWSER, 0, 0, pWindow.ClientWidth, pWindow.ClientHeight)
   ' // Set the IDocHostUIHandler interface
   pwb.SetUIHandler
   ' // Build the script
   DIM s AS STRING = BuildScript
   ' // Save the script as a temporary file
   DIM wszPath AS WSTRING * MAX_PATH = AfxSaveTempFile(s, "html")
   ' // Navigate to the path
   pwb.Navigate(wszPath)
   ' // Processes pending Windows messages to allow the page to load
   AfxPumpMessages
   ' // Kill the temporary file
   KILL wszPath
' Main window procedure
   SELECT CASE uMsg
      CASE WM_COMMAND
         SELECT CASE LOWORD(wParam)
            CASE IDCANCEL
      CASE WM_SIZE
         ' // Optional resizing code
            ' // Move the position of the control
            IF pWindow THEN pWindow->MoveWindow GetDlgItem(hwnd, IDC_WEBBROWSER), _
               0, 0, pWindow->ClientWidth, pWindow->ClientHeight, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
#3
CWSTR.INC update
I have optimized some of the constructors to not preallocate memory if unneeded and added overloads for LEFT, RIGHT, VAL and the & operator. Now they can be used without having to double deference the string, although doing it is still, and will ever be, the fastest way. Using the operator + with CWSTR is also faster than using &.
I also have added the function pthis that returns the address of the CWSTR, since @ and VARPTR are used by the class to return the address of the underlying string buffer. You only will need this function if you want to declare a parameter as BYVAL CWSTR PTR instead of BYREF CWSTR.
Modified AfxUcode to work with CWSTR, The previous version used a BSTR.
' Translates ansi bytes to unicode bytes.
' Parameters:
' - ansiStr = An ansi or UTF8 string.
' - nCodePage = The code page used in the conversion, e.g. 1251 for Russian.
'   If you specify CP_UTF8, the returned string will be UTF8 encoded.
'   If you don't pass an unicode page, the function will use CP_ACP (0), which is the
'   system default Windows ANSI code page.
' Return value:
'   The converted string as a CWSTR.
PRIVATE FUNCTION AfxUcode (BYREF ansiStr AS CONST STRING, BYVAL nCodePage AS LONG = 0) AS CWSTR
   IF nCodePage = CP_UTF8 THEN
      DIM dwLen AS DWORD = MultiByteToWideChar(CP_UTF8, 0, STRPTR(ansiStr), LEN(ansiStr), NULL, 0)
      IF dwLen THEN
         DIM cws AS CWSTR = SPACE(dwLen)
         dwLen = MultiByteToWideChar(CP_UTF8, 0, STRPTR(ansiStr), LEN(ansiStr), @cws, dwLen * 2)
         IF dwLen THEN RETURN cws
      DIM cws AS CWSTR = SPACE(LEN(ansiStr))
      DIM dwLen AS DWORD = MultiByteToWideChar(nCodePage, MB_PRECOMPOSED, STRPTR(ansiStr), LEN(ansiStr), @cws, LEN(ansiStr) * 2)
#5
CWSTR.INC update
Changed the constructor with the CodePage parameter to accept the Capacity parameter instead. This way, we can pre-allocate the capacity when declaring the variable, e.g. DIM cws AS CWSTR = 260 * 2.
Added a boolean fAttach parameter to the constructor that accepts a WSTRING pointer to allow faster concatenations using the & operators.
Modified the & operators for faster concatenations.
CWSTR.INC update
Some additional changes and optimizations. Thanks to Marc Pons for testing the class and for his suggestions.
