Pages: 1 [2] 3
Author Topic: WinFBE on GitHub (December 6, 2016)  (Read 9237 times)
Re: WinFBE on GitHub (December 6, 2016)
« Reply #15 on: December 22, 2016, 06:10:20 AM »
Works fine, but maybe you should made it optional.
« Reply #16 on: December 22, 2016, 01:27:17 PM »
Editor work pretty cool.
Now for my usual dumb question.
The samples with the latest Jose includes...
I can see the files under the Editor folder /AFX but still get File not found error.
It must be a setting i am missing as usual.
« Reply #17 on: December 22, 2016, 02:09:55 PM »
There are no samples in the editor's Afx folder. There are templates in the Templates folder and projects in the Sample_Projects folder.
« Reply #18 on: December 22, 2016, 02:19:59 PM »
..or, if you mean my include files, you must download them from here: http://www.planetsquires.com/protect/forum/index.php?topic=3966.0
...and copy them to the "inc" folder of your FreeBasic installation, e.g. C:\Users\Pepe\FreeBasic32\inc\Afx and C:\Users\Pepe\FreeBasic64\inc\Afx.
« Reply #19 on: December 22, 2016, 02:25:52 PM »
LOL, yes, i actually had them.
I still get errors on the same place.
I am trying to look at the examples like the Split button and the toolbars that came in the download.
« Reply #20 on: December 22, 2016, 02:53:30 PM »
You must always to use the latest version of the includes, not an old one.
« Reply #21 on: December 22, 2016, 04:13:55 PM »
Thanks Jose, yes it already is optional. There is a setting in Editor Options. One for Codetips (that doesn't do anything yet) and one for Autocomplete (which is what this feature is).
« Reply #22 on: December 22, 2016, 04:20:55 PM »
I don't see it.
« Reply #23 on: December 22, 2016, 09:49:10 PM »
I don't see it.
Well that's odd. I recompiled the EXE's and uploaded them again for you. Use the EXE's from the GitHub ZIP file download rather than the "Release" download. The screen should look like this attachment:
Tasos Georgas
  • Little Newbie
« Reply #24 on: December 23, 2016, 03:51:19 AM »
You have to #include once "C:\FreeBASIC\inc\win\windowsx.bi"
Or there is  "C:\WinFBE-master\src\windowsxx.bi" that you can include, too.
I don't know why that is missed from the code.
Tasos Georgas.
« Reply #25 on: December 23, 2016, 04:58:41 AM »
Tasos Georgas.
The latest include files already use windowsx.bi. He must be using an older version.
« Reply #26 on: December 23, 2016, 05:28:35 AM »
> Well that's odd.
Very odd, indeed. I have needed to do a new install. Overwriting or copying the .exe files only did not work, I wonder why.
Guess it has to do with the language files. You have changed them to add the new option.
« Last Edit: December 23, 2016, 05:42:42 AM by Jose Roca »
« Reply #27 on: December 23, 2016, 06:18:58 AM »
Updated Spanish language file.
You need to make one of the labels a bit bigger (the last four characters aren't being displayed).
« Reply #28 on: December 23, 2016, 10:48:44 AM »
Thanks Jose - appreciate the updated language file! I have also made the visual change to the New Project Options dialog to ensure enough space for the label. I will update GitHub later today.
« Reply #29 on: December 23, 2016, 07:52:23 PM »
I updated GitHub with the changes as well as including new code that displays a popup list of data types when "AS" is typed. Seems to be working well so far.
Pages: 1 [2] 3
