WinFBE on GitHub (December 6, 2016)
Started by Paul Squires, December 06, 2016, 08:02:28 PM
I also created a "Release" on GitHub for this 1.1.0 version. My first time doing that. It is pretty cool because it allows for a snapshot of all code and binaries at that specific point in time should we ever need to test the code at some point in the future.
Version 1.1.0 (December 6, 2016)
- Added: Subfolder called "Sample_Projects" containing many sample projects as written by Jose Roca.
- Added: StatusBar panel 5 shows current compile results (Errors/Warnings). Clicking that panel shows/hide Output window.
- Added: Change cursor to hourglass during compile process.
- Changed: Project files are now saved to the project file as relative to the project disk filename (*.wfbe).
- Changed: Updated the Scintilla 32-bit DLL to version 3.7.1.
- Fixed: Situation where newly created untitled source filename could be saved to a project file (*.wfbe).
- Fixed: Correct font for Compiler Log output to be HighDPI aware.
- Fixed: Dropping of files onto editor (frmMain_OnDropFiles) now correctly opens regular files or projects.
- Fixed: Problem with "Untitled.bas*" files persisting in Project Explorer list even when untitled source file is closed.
- Fixed: Situation where removing/closing a file would continue to show its list of functions in the popup Function List.
#1
CULNG is missing in the list of keywords. Also CULNGINT.
Currently, Ctrl+W is doing the same as Ctrl+Q, i.e. closing the current tab. I suggest to use Ctrl+W to switch tabs.
Two new projects. A Toolbar inside a rebar and a treeview with imagelist.
A new project: RichOleDemo.
Two frequently asked questions are how to load a rich edit text file using the EM_STREAMIN message and how to display images embedded in the file.
This demo implements the wrapper function RichEdit_LoadRtfFromFileW and the IRichEditOleCallback interface.
' Microsoft Windows
' File: RichOleDemo.bas
' Contents: Demonstrates how to load a rich edit text file and how to implement the
' IRichEditOleCallback interface, which allows to display embedded images.
#define UNICODE
#INCLUDE ONCE "Afx/AfxCOM.inc"
USING Afx
CONST IDC_RICHEDIT = 1001
' // Forward declaration
' The EditStreamCallback function is an application defined callback function used with
' the EM_STREAMIN and EM_STREAMOUT messages. It is used to transfer a stream of data into
' or out of a rich edit control.
FUNCTION RichEdit_LoadRtfFromFileCallback ( _
   BYVAL hFile AS HANDLE _                  ' // Value of the dwCookie member of the EDITSTREAM structure.
, BYVAL lpBuff AS BYTE PTR _               ' // Pointer to a buffer to write to
, BYVAL cb AS LONG _                       ' // Maximum number of bytes to read
, BYVAL pcb AS LONG PTR _                  ' // Number of bytes actually read
) AS UINT                                  ' // 0 for success, or an error code
   IF ReadFile(hFile, lpBuff, cb, pcb, NULL) = 0 THEN FUNCTION = GetLastError
FUNCTION RichEdit_LoadRtfFromFileW ( _
   BYVAL hRichEdit AS HWND _                ' // Handle of the Rich Edit control
, BYREF wszFileName AS WSTRING _           ' // Name of the file to load
) AS BOOLEAN                               ' // TRUE or FALSE
   DIM hFile AS HANDLE                      ' // File handle
   DIM eds AS EDITSTREAM                    ' // EDITSTREAM structure
   ' // Checks the validity of the parameters
   IF hRichEdit = 0 THEN EXIT FUNCTION
   IF LEN(wszFileName) = 0 THEN EXIT FUNCTION
   ' // Opens the file and sends the message
   hFile = CreateFileW(wszFileName, GENERIC_READ, FILE_SHARE_READ, _
                       BYVAL NULL, OPEN_EXISTING, FILE_FLAG_SEQUENTIAL_SCAN, NULL)
   IF hFile = INVALID_HANDLE_VALUE THEN EXIT FUNCTION
   eds.dwCookie = cast(DWORD_PTR, hFile)
   eds.dwError = 0
   eds.pfnCallback = cast(EDITSTREAMCALLBACK, @RichEdit_LoadRtfFromFileCallback)
   IF SendMessageW(hRichEdit, EM_STREAMIN, SF_RTF, cast(LPARAM, @eds)) > 0 AND eds.dwError = 0 THEN FUNCTION = TRUE
   CloseHandle hFile
#ifndef __Afx_IRichEditOleCallback_INTERFACE_DEFINED__
#define __Afx_IRichEditOleCallback_INTERFACE_DEFINED__
TYPE Afx_IRichEditOleCallback AS Afx_IRichEditOleCallback_
TYPE Afx_IRichEditOleCallback_ EXTENDS Afx_IUnknown
DECLARE ABSTRACT FUNCTION GetNewStorage (BYVAL lplpstg AS LPSTORAGE PTR) AS HRESULT
DECLARE ABSTRACT FUNCTION GetInPlaceContext (BYVAL lplpFrame AS LPOLEINPLACEFRAME PTR, BYVAL lplpDoc AS LPOLEINPLACEUIWINDOW PTR, BYVAL lpFrameInfo AS LPOLEINPLACEFRAMEINFO) AS HRESULT
DECLARE ABSTRACT FUNCTION ShowContainerUI (BYVAL fShow AS WINBOOL) AS HRESULT
DECLARE ABSTRACT FUNCTION QueryInsertObject (BYVAL lpclsid AS LPCLSID, BYVAL lpstg AS LPSTORAGE, BYVAL cp AS LONG) AS HRESULT
DECLARE ABSTRACT FUNCTION DeleteObject (BYVAL lpoleobj AS LPOLEOBJECT) AS HRESULT
DECLARE ABSTRACT FUNCTION QueryAcceptData (BYVAL lpdataobj AS LPDATAOBJECT, BYVAL lpcfFormat AS CLIPFORMAT PTR, BYVAL reco AS DWORD, BYVAL fReally AS WINBOOL, BYVAL hMetaPict AS HGLOBAL) AS HRESULT
DECLARE ABSTRACT FUNCTION ContextSensitiveHelp (BYVAL fEnterMode AS WINBOOL) AS HRESULT
DECLARE ABSTRACT FUNCTION GetClipboardData (BYVAL lpchrg AS CHARRANGE PTR, BYVAL reco AS DWORD, BYVAL lplpdataobj AS LPDATAOBJECT PTR) AS HRESULT
DECLARE ABSTRACT FUNCTION GetDragDropEffect (BYVAL fDrag AS WINBOOL, BYVAL grfKeyState AS DWORD, BYVAL pdwEffect AS LPDWORD) AS HRESULT
DECLARE ABSTRACT FUNCTION GetContextMenu (BYVAL seltype AS WORD, BYVAL lpoleobj AS LPOLEOBJECT, BYVAL lpchrg AS CHARRANGE PTR, BYVAL lphmenu AS HMENU PTR) AS HRESULT
END TYPE
TYPE AFX_LPRICHEDITOLECALLBACK AS Afx_IRichEditOleCallback PTR
#endif
TYPE Afx_IRichEditOleCallbackImpl EXTENDS Afx_IRichEditOleCallback
   DECLARE VIRTUAL FUNCTION QueryInterface (BYVAL AS REFIID, BYVAL AS PVOID PTR) AS HRESULT
   DECLARE VIRTUAL FUNCTION AddRef () AS ULONG
   DECLARE VIRTUAL FUNCTION Release () AS ULong
   DECLARE VIRTUAL FUNCTION GetNewStorage (BYVAL lplpstg AS LPSTORAGE PTR) AS HRESULT
   DECLARE VIRTUAL FUNCTION GetInPlaceContext (BYVAL lplpFrame AS LPOLEINPLACEFRAME PTR, BYVAL lplpDoc AS LPOLEINPLACEUIWINDOW PTR, BYVAL lpFrameInfo AS LPOLEINPLACEFRAMEINFO) AS HRESULT
   DECLARE VIRTUAL FUNCTION ShowContainerUI (BYVAL fShow AS WINBOOL) AS HRESULT
   DECLARE VIRTUAL FUNCTION QueryInsertObject (BYVAL lpclsid AS LPCLSID, BYVAL lpstg AS LPSTORAGE, BYVAL cp AS LONG) AS HRESULT
   DECLARE VIRTUAL FUNCTION DeleteObject (BYVAL lpoleobj AS LPOLEOBJECT) AS HRESULT
   DECLARE VIRTUAL FUNCTION QueryAcceptData (BYVAL lpdataobj AS LPDATAOBJECT, BYVAL lpcfFormat AS CLIPFORMAT PTR, BYVAL reco AS DWORD, BYVAL fReally AS WINBOOL, BYVAL hMetaPict AS HGLOBAL) AS HRESULT
   DECLARE VIRTUAL FUNCTION ContextSensitiveHelp (BYVAL fEnterMode AS WINBOOL) AS HRESULT
   DECLARE VIRTUAL FUNCTION GetClipboardData (BYVAL lpchrg AS CHARRANGE PTR, BYVAL reco AS DWORD, BYVAL lplpdataobj AS LPDATAOBJECT PTR) AS HRESULT
   DECLARE VIRTUAL FUNCTION GetDragDropEffect (BYVAL fDrag AS WINBOOL, BYVAL grfKeyState AS DWORD, BYVAL pdwEffect AS LPDWORD) AS HRESULT
   DECLARE VIRTUAL FUNCTION GetContextMenu (BYVAL seltype AS WORD, BYVAL lpoleobj AS LPOLEOBJECT, BYVAL lpchrg AS CHARRANGE PTR, BYVAL lphmenu AS HMENU PTR) AS HRESULT
   DECLARE CONSTRUCTOR
   DECLARE DESTRUCTOR
   cRef AS DWORD                       ' // Reference count
END TYPE
' Constructor
CONSTRUCTOR Afx_IRichEditOleCallbackImpl
END CONSTRUCTOR
' Destructor
DESTRUCTOR Afx_IRichEditOleCallbackImpl
END DESTRUCTOR
' Returns pointers to the implemented classes and supported interfaces.
FUNCTION Afx_IRichEditOleCallbackImpl.QueryInterface (BYVAL riid AS REFIID, BYVAL ppvObj AS LPVOID PTR) AS HRESULT
   IF ppvObj = NULL THEN RETURN E_INVALIDARG
   DIM IID_IRichEditOleCallback_ AS GUID = (&h00020D03, &h0000, &h0000, {&hC0, &h00, &h00, &h00, &h00, &h00, &h00, &h46})
   IF IsEqualIID(riid, @IID_IRichEditOleCallback_) OR IsEqualIID(riid, @IID_IUnknown) OR IsEqualIID(riid, @IID_IDispatch) THEN
      *ppvObj = @this
      ' // Not really needed, since this is not a COM object
      cast(Afx_IUnknown PTR, *ppvObj)->AddRef
      RETURN S_OK
   RETURN E_NOINTERFACE
FUNCTION Afx_IRichEditOleCallbackImpl.AddRef () AS ULONG
   RETURN 2
FUNCTION Afx_IRichEditOleCallbackImpl.Release () AS ULONG
   RETURN 1
FUNCTION Afx_IRichEditOleCallbackImpl.GetNewStorage (BYVAL lplpstg AS LPSTORAGE PTR) AS HRESULT
   DIM hr AS HRESULT, pILockBytes AS ILockBytes PTR
   hr = CreateILockBytesOnHGlobal(NULL, TRUE, @pILockBytes)
   IF FAILED(hr) THEN RETURN hr
   hr = StgCreateDocfileOnILockBytes(pILockBytes, _
        STGM_SHARE_EXCLUSIVE OR STGM_READWRITE OR STGM_CREATE, 0, lplpstg)
   RETURN hr
FUNCTION Afx_IRichEditOleCallbackImpl.GetInPlaceContext (BYVAL lplpFrame AS LPOLEINPLACEFRAME PTR, BYVAL lplpDoc AS LPOLEINPLACEUIWINDOW PTR, BYVAL lpFrameInfo AS LPOLEINPLACEFRAMEINFO) AS HRESULT
   RETURN E_NOTIMPL
FUNCTION Afx_IRichEditOleCallbackImpl.ShowContainerUI (BYVAL fShow AS WINBOOL) AS HRESULT
   RETURN E_NOTIMPL
FUNCTION Afx_IRichEditOleCallbackImpl.QueryInsertObject (BYVAL lpclsid AS LPCLSID, BYVAL lpstg AS LPSTORAGE, BYVAL cp AS LONG) AS HRESULT
   RETURN S_OK
FUNCTION Afx_IRichEditOleCallbackImpl.DeleteObject (BYVAL lpoleobj AS LPOLEOBJECT) AS HRESULT
   RETURN S_OK
FUNCTION Afx_IRichEditOleCallbackImpl.QueryAcceptData (BYVAL lpdataobj AS LPDATAOBJECT, BYVAL lpcfFormat AS CLIPFORMAT PTR, BYVAL reco AS DWORD, BYVAL fReally AS WINBOOL, BYVAL hMetaPict AS HGLOBAL) AS HRESULT
   RETURN E_NOTIMPL
FUNCTION Afx_IRichEditOleCallbackImpl.ContextSensitiveHelp (BYVAL fEnterMode AS WINBOOL) AS HRESULT
   RETURN E_NOTIMPL
FUNCTION Afx_IRichEditOleCallbackImpl.GetClipboardData (BYVAL lpchrg AS CHARRANGE PTR, BYVAL reco AS DWORD, BYVAL lplpdataobj AS LPDATAOBJECT PTR) AS HRESULT
   RETURN E_NOTIMPL
FUNCTION Afx_IRichEditOleCallbackImpl.GetDragDropEffect (BYVAL fDrag AS WINBOOL, BYVAL grfKeyState AS DWORD, BYVAL pdwEffect AS LPDWORD) AS HRESULT
   RETURN E_NOTIMPL
FUNCTION Afx_IRichEditOleCallbackImpl.GetContextMenu (BYVAL seltype AS WORD, BYVAL lpoleobj AS LPOLEOBJECT, BYVAL lpchrg AS CHARRANGE PTR, BYVAL lphmenu AS HMENU PTR) AS HRESULT
   RETURN E_NOTIMPL
' Main
   ' // Set process DPI aware
   ' // The recommended way is to use  manifest
'   AfxSetProcessDPIAware
   ' // Initialize the COM library
   CoInitialize NULL
   ' // Create the main window
   DIM pWindow AS CWindow
   pWindow.Create(NULL, "Rich Ole Demo", @WndProc)
   ' // Set the client size
   pWindow.SetClientSize(750, 450)
   ' // Center the window
   pWindow.Center
   ' // Add a rich edit control without coordinates (it will be resized in WM_SIZE)
   DIM hRichEdit AS HWND = pWindow.AddControl("RichEdit", , IDC_RICHEDIT, "RichEdit box", , , , , _
   WS_VISIBLE OR WS_TABSTOP OR ES_LEFT OR WS_VSCROLL OR ES_MULTILINE OR ES_WANTRETURN OR ES_NOHIDESEL OR ES_SAVESEL)
   ' // Raise the 32,767 default characters limit to no limit
   SendMessageW(hRichEdit, EM_EXLIMITTEXT, 0, -1)
   ' // Set the left margin
   SendMessageW(hRichEdit, EM_SETMARGINS, EC_LEFTMARGIN, 20)
   ' // Specify which notifications the control sends to its parent window
   SendMessageW(hRichEdit, EM_SETEVENTMASK, 0, ENM_CHANGE)
   ' // Set the IRichEditOleCallback object.
   ' // The control calls the AddRef function for the object before returning.
   DIM pRichEditOleCallback AS Afx_IRichEditOleCallbackImpl PTR = NEW Afx_IRichEditOleCallbackImpl
   SendMessageW(hRichEdit, EM_SETOLECALLBACK, 0, cast(LPARAM, pRichEditOleCallback))
   ' // Load the file
   RichEdit_LoadRtfFromFileW hRichEdit, ".\Resources\The_Third_Man.rtf"
   ' // Set the focus in the control
   SetFocus hRichEdit
   ' // Delete the class
   IF pRichEditOleCallback THEN Delete pRichEditOleCallback
   ' // Uninitialize the COM library
   CoUninitialize
   SELECT CASE uMsg
      CASE WM_COMMAND
            CASE IDCANCEL
      CASE WM_SIZE
         ' // If the window isn't minimized, resize it
            ' // Resize the Rich Edit control
            DIM hRichEdit AS HWND = GetDlgItem(hwnd, IDC_RICHEDIT)
            MoveWindow hRichEdit, 10, 10, LOWORD(lParam) - 20, HIWORD(lParam) - 20, CTRUE
    CASE WM_DESTROY
         PostQuitMessage(0)
Quote from: Jose Roca on December 11, 2016, 08:23:19 PM
Hi Jose, the logic I used was based on this previous post: http://www.planetsquires.com/protect/forum/index.php?topic=3890.msg28794#msg28794
Jose, thanks for the new sample projects! I have added them to GitHub.  :)
Quote from: TechSupport on December 14, 2016, 04:38:52 PM
Then you can use Ctrl+Tab to switch tabs.
There is still a problem when using projects: after using a project with a resource and closing it, if you try to compile a .bas file, it fails because it tries to compile also the resource of the closed project, forcing you to restart the editor.
Quote from: Jose Roca on December 15, 2016, 03:25:46 AM
Thanks Jose, yes you are correct. I was able to reproduce the problem and have now fixed it. New code and exe's are now in GitHub.
Andrew Lindsay
Paul / Jose,
Just a quick note to say thanks for your hard work and efforts for the community.  While I am not in a position to play with your tools or code examples at the moment, I am sitting back dreaming of days less concerned with broken pumps and leaking tubes, driving Excel spreadsheets and delving into long forgotten fluid flow equations.
But please accept my appreciation and understand my anticipation for some free time at home with my family and my computer to play.
Andrew
Thanks Andrew! That is so nice of you to say. Really appreciate the kind words.
I admit that these days programming is more relaxing for me as I do it now as a nice hobby and without the expectations that come with supporting commercial software. Using FreeBasic and creating open source tools is a refreshing experience. I'll never be able to churn out as much code as Jose does but it is satisfying when I create something useful.
All the best to you and hope you can pick up programming again soon!  :)
Should have Autocomplete finished tomorrow. Once again stole some code from Jose's awesome CSED Editor.
Autocomplete works by inserting a fragment of code based on an initial keyword. For example, typing "FOR" and then pressing the space key will insert a blank FOR/NEXT code fragment, etc.  Pretty cool.
Codetips will come after this Autocomplete is finished.
Autocomplete added to GitHub:
- Added: Autocomplete feature for IF/WHILE/FOR/SELECT/FUNCTION/SUB/PROPERTY/TYPE/UNION
If you are happy with this new functionality then I will release a new package via GitHub. Will number it version 1.2.0
