how do I change attributes of a control within the program
Started by raymw, January 25, 2017, 07:27:45 PM
How do I change a control within the program, e.g. change background colour and size of textbox, say, from the original design. Can anyone point me towards an example, or prepared to write a code snippet and explain. Thanks
Best wishes,
Ray
Some controls allow you to change the coloring on the fly but others do not easily (for example, Common Controls and Command/Push Buttons). For many of the standard basic Window controls (Labels, TextBoxes), you can use the FF_Control_SetColor function passing it RGB color values for foreground and background. For example,
   FF_Control_SetColor( HWND_FORM1_A, BGR(255,255,255), BGR(100,100,100) )
Notice that in FreeBasic the function is not called RGB but rather BGR.
To change control sizes you can use the FireFly function: FF_Control_SetSize
...or, use the WinAPI functions SetWindowPos or MoveWindow.
thanks. so far, so good, at least with color change of text boxes
