Author Topic: QR codes  (Read 1916 times)
QR codes
« on: September 28, 2017, 04:25:30 PM »
Hi all
Has anyone here worked with creating QR codes in Powerbasic or Freebasic?
Finally got my hands on a proper multi-code scanner.
The examples on the web are limited to a few pictures in powerbasic but no source code.
It way more complicated than the regular barcode encoding.
I will really appreciate any help.
Wilko Verweij
  • PB10 - FF3.7 User; Win 10
    • CHEAQS
Re: QR codes
« Reply #2 on: September 29, 2017, 08:29:49 AM »
Hi
Thanks, these are the ones i have been looking at but the source code is missing.
The compiled project i have and it works great, if i only could find a way to make this work in a project.
Thanks again for the help.
Re: QR codes
« Reply #3 on: September 29, 2017, 08:32:58 AM »
Got a project with code i can look at!
Will keep you updated if i have progress!
