Author Topic: Treeview question  (Read 1609 times)
Treeview question
« on: November 10, 2017, 04:37:06 PM »
Hi all
I made a little phonebook for my sms tool with a treeview, nodes A-C, D-F, etc.
It works ok with adding the numbers under the alphabet roots, but it also suck at the same time.
I like the fact i can click on a Node and it displays the list of sub-entries, but i would rather have them neatly in columns.
Could one "emulate" this node appearance in perhaps a listview or could one perhaps order the Cell number, surname and initials neatly into exact columns in the treeview?
« Last Edit: November 10, 2017, 04:38:59 PM by Petrus Vorster »
Klaas Holland
Re: Treeview question
« Reply #1 on: November 11, 2017, 05:47:05 AM »
Hi Petrus,
I would suggest a listview.
David Kenny
  • Windows 7 & 10
« Reply #2 on: November 16, 2017, 05:55:29 PM »
If I understand what you want correctly, then using a fixed-width font, instead of a proportional font, might be what you are looking for.
« Reply #3 on: November 18, 2017, 04:00:27 AM »
Hi David
Yes, eventually i went for SYSTEm font.
But i have decided to rather make a small listview so i can sort the contents.
Its strange that just after one solved a situation, how quickly you can think of changing it again!!
Thanks
Peter.
