Author Topic: FireFly Crash  (Read 1640 times)
FireFly Crash
« on: December 02, 2017, 05:50:03 PM »
I never had a Firefly crash of this nature before.
I created three Tab child forms, and they worked just fine.
Then i copied a button from another form and then all hell broke loose.
The form loads, but is changes size, background colour, loses its name, and continues to give me endless errors.
I removed it, re-wrote it, re-saved it. NOPE, once Firefly starts it corrupts the specific form file again.
I have so much work done on it, why on earth would it continue to refuse to cave changes and corrupt everything?
Very weird.
Re: FireFly Crash
« Reply #1 on: December 02, 2017, 06:48:58 PM »
Hmmmmm..... not sure but you might have to manually edit the .frm file with Notpad (or other ascii text editor) to remove offending code?
Re: FireFly Crash
« Reply #2 on: December 03, 2017, 06:41:26 AM »
Hi Paul.
Eventually i had to copy all the stuff i typed, delete the entire form again, re-compile, and create it again from scratch.
Then just used the info i kept for all the functions.
Whoah, never before had i seen that happen. Wont copy a button from one form to another again!! :)
