Author Topic: Compiler error I do not understand  (Read 1565 times)
Wilko Verweij
  • PB10 - FF3.7 User; Win 10
    • CHEAQS
« on: February 28, 2018, 03:41:04 PM »
Hi, I get a compiler error that I do not understand. The error is:
4 Duplicated definition, Outp in 'dim shared Outp As OutputType'
and it occurs in the last line of the code below. The contents of the UDT don't matter, it is in the name of the variable 'Outp' for when I change it, the compiler error disappears. Of course I can use a different name but I would like to understand why this error occurs. AFAIK it is not a keyword or so. And there is no variable with this name elsewhere in the program. Any help is appreciated.
Wilko
Type OutputType
  Send2Screen As boolean
  Send2Printer As boolean
  Send2File As boolean
  Send2Csv As boolean
  Send2XML As boolean
  DisplaySummary As boolean
  DisplayDetails As boolean
  DisplayOtherInfo As boolean
  DisplayGraphs As boolean
End Type
Re: Compiler error I do not understand
« Reply #1 on: February 28, 2018, 04:01:44 PM »
There is a function called outp in intrin.bi (in the FreeBasic headers).
Wilko Verweij
    • CHEAQS
« Reply #2 on: February 28, 2018, 04:03:11 PM »
OK, that explains the error. Thanks, Jose!
