Author Topic: FireFly 3 ctl-files  (Read 1448 times)
Christian Weilguny
  • FF3 Newbie
FireFly 3 ctl-files
« on: April 14, 2018, 09:16:45 PM »
Hello,
I have a new problem width building a ctl-file.
I have to make the following definition:
prop_action = USER32.DLL|SendMessage|SendMessageA|BYVAL LONG //CTRL_HWND//|BYVAL LONG MESSAGE|BYVAL LONG //PROP_VALUE//|BYVAL LONG %null
where the PROP_VALUE is a string and I have to put the pointer to this string.
How can I do this?
Thanks in advance
Christian
Re: FireFly 3 ctl-files
« Reply #1 on: April 17, 2018, 08:59:14 AM »
Hi Christian,
It's been a long, long, long time since I've done any work in this area. You could try the following and see if it works:
prop_action = USER32.DLL|SendMessage|SendMessageA|BYVAL LONG //CTRL_HWND//|BYVAL LONG MESSAGE|BYVAL ASCIIZ //PROP_VALUE//|BYVAL LONG %NULL
Christian Weilguny
  • FF3 Newbie
« Reply #2 on: April 17, 2018, 11:37:36 AM »
Hello Paul,
this way I tried first.
The control loads correct in Firefly and I can change the value.
Then a compiletime error  occured, because the type is not long.
kind regards
Christian
Christian Weilguny
  • FF3 Newbie
« Reply #3 on: April 17, 2018, 12:31:38 PM »
Now I have figured out if I use 'BYVAL VARPTR //PROP_VALUE//' I can compile the program and the value is correct used.
Unfortunatly every formatting after this in code (WM_Create) is not processed.
If I format the string in code I have to use STRPTR, but in the ctl-file this crashes Firefly loading the project.
Kind regards
Christian
