Author Topic: Context Sensitive Help  (Read 1512 times)
« on: April 25, 2018, 09:28:49 PM »
Hello,
Trying to get a "?" question mark to appear in a form's caption bar. Checked the option in ExStyles but I may have the wrong type of dialog frame selected as no "?" appears.
Also, the "?" will be used for context sensitive help in (the form of) a .chm file but I'm struggling with the API that (I think) is what I need to get the chm file open. (In VB I used App.HelpFile = App.Path & "\myhelpfile.chm"...)
Any help/ideas would be appreciated.
Thanks
Clive
Re: Context Sensitive Help
« Reply #1 on: April 25, 2018, 10:39:19 PM »
https://msdn.microsoft.com/en-us/library/windows/desktop/ff700543(v=vs.85).aspx
The title bar of the window includes a question mark. When the user clicks the question mark, the cursor changes to a question mark with a pointer. If the user then clicks a child window, the child receives a WM_HELP message. The child window should pass the message to the parent window procedure, which should call the WinHelp function using the HELP_WM_HELP command. The Help application displays a pop-up window that typically contains help for the child window.
WS_EX_CONTEXTHELP cannot be used with the WS_MAXIMIZEBOX or WS_MINIMIZEBOX styles.
« Reply #2 on: April 25, 2018, 10:47:01 PM »
Context sensitive help... here is what I use for WinFBE:
at start of program, load the library
'  Global handle to hhctrl.ocx for context sensitive help
Dim Shared As Any Ptr gpHelpLib
 ' Load the HTML help library for displaying FreeBASIC help *.chm file
 gpHelpLib = DyLibLoad( "hhctrl.ocx" )
' Before program ends, unload the library
   ' Free the HTML help library
   Dylibfree(gpHelpLib)
'    WinFBE - Programmer's Code Editor for the FreeBASIC Compiler
'    Copyright (C) 2016 Paul Squires, PlanetSquires Software
'    This program is free software: you can redistribute it and/or modify
'    it under the terms of the GNU General Public License as published by
'    the Free Software Foundation, either version 3 of the License, or
'    (at your option) any later version.
'    This program is distributed in the hope that it will be useful,
'    but WITHOUT any WARRANTY; without even the implied warranty of
'    MERCHANTABILITY or FITNESS for A PARTICULAR PURPOSE.  See the
'    GNU General Public License for more details.
' Size = 32 bytes
TYPE HH_AKLINK
   cbStruct     AS LONG         ' int       cbStruct;     // sizeof this structure
   fReserved    AS BOOLEAN      ' BOOL      fReserved;    // must be FALSE (really!)
   pszKeywords  AS WSTRING PTR  ' LPCTSTR   pszKeywords;  // semi-colon separated keywords
   pszUrl       AS WSTRING PTR  ' LPCTSTR   pszUrl;       // URL to jump to if no keywords found (may be NULL)
   pszMsgText   AS WSTRING PTR  ' LPCTSTR   pszMsgText;   // Message text to display in MessageBox if pszUrl is NULL and no keyword match
   pszMsgTitle  AS WSTRING PTR  ' LPCTSTR   pszMsgTitle;  // Message text to display in MessageBox if pszUrl is NULL and no keyword match
   pszWindow    AS WSTRING PTR  ' LPCTSTR   pszWindow;    // Window to display URL in
   fIndexOnFail AS BOOLEAN      ' BOOL      fIndexOnFail; // Displays index if keyword lookup fails.
END TYPE
#Define HH_DISPLAY_TOPIC   0000
#Define HH_DISPLAY_TOC     0001
#Define HH_KEYWORD_LOOKUP  0013
#Define HH_HELP_CONTEXT    0015
' Show context help or general contents if word does not exist
Function ShowContextHelp() As Long
   Dim HtmlHelpW As Function ( BYVAL hwndCaller AS HWnd, _
                               BYVAL pswzFile AS WSTRING Ptr, _
                               BYVAL uCommand AS UNIT, _
                               BYVAL dwData AS DWORD_PTR _
                               ) AS HWND
   ' Ensure that the CurDrive parameter is converted if applicable
   gConfig.CompilerHelpFile = ProcessFromCurdrive( gConfig.CompilerHelpFile )
   If AfxFileExists(gConfig.CompilerHelpFile) = 0 Then
      MessageBoxW( HWND_FRMMAIN, L(244,"FreeBASIC Help file not found."), L(201,"Error"), _
                    MB_OK Or MB_ICONWARNING Or MB_DEFBUTTON1 Or MB_APPLMODAL )
      Exit Function
   HtmlHelpW = DyLibSymbol( gpHelpLib, "HtmlHelpW" )
   If (gpHelpLib = 0) OrElse (HtmlHelpW = 0) Then
      MessageBoxW( HWND_FRMMAIN, L(243,"Error loading HtmlHelp."), L(201,"Error"), _
      Exit Function
   ' If we are currently in an active document then attempt to lookup the
   ' word immediately under the caret.
   Dim pDoc as clsDocument Ptr = gTTabCtl.GetActiveDocumentPtr()
   If pDoc = 0 Then
      HtmlHelpW( 0, gConfig.CompilerHelpFile, HH_DISPLAY_TOC, NULL )
      Exit Function
   ENd If
   Dim wszKeyword as WString * MAX_PATH
   wszKeyword = WStr( pDoc->GetWord )
   Dim li As HH_AKLINK
   With li
      .cbStruct     = SizeOf(HH_AKLINK)
      .fReserved    = FALSE
      .pszKeywords  = @wszKeyword
      .pszUrl       = Null
      .pszMsgText   = Null
      .pszMsgTitle  = Null
      .pszWindow    = Null
      .fIndexOnFail = FALSE
   End With
   ' Open the help and show the topic
   HtmlHelpW( 0, gConfig.CompilerHelpFile, HH_DISPLAY_TOC, Null )   '<-- needed?
   If HtmlHelpW( 0, gConfig.CompilerHelpFile, HH_KEYWORD_LOOKUP, Cast(DWORD_PTR, @li) ) = 0 Then
      ' Normal case search failed, try a ucase search
      wszKeyword     = UCase(wszKeyword)
      li.pszKeywords = @wszKeyword
   Function = 0
« Reply #3 on: April 26, 2018, 12:11:09 AM »
Thanks, Paul! I had WS_MINIMIZEBOX set.
