Author Topic: Problems with Windows 10  (Read 2550 times)
« on: April 26, 2018, 08:54:58 AM »
I have bought a new HP computer with Intel i5-7500 3,4 GHz and I'm having problems trying to use FreeBasic with it.
Just using
generates the following output (using -v -showincludes to display the tree of included files):
FreeBASIC Compiler - Version 1.05.0 (01-31-2016), built for win32 (32bit)
standalone
compiling:    C:\Programación\Tests\x.bas -o C:\Programación\Tests\x.asm (main module)
x.bas
 |  C:\Programación\FreeBasic32\inc\windows.bi
 |   |  C:\Programación\FreeBasic32\inc\crt\stdarg.bi
 |   |  C:\Programación\FreeBasic32\inc\win\windef.bi
 |   |   |  C:\Programación\FreeBasic32\inc\win\_mingw.bi
 |   |   |  C:\Programación\FreeBasic32\inc\win\winapifamily.bi
 |   |   |  C:\Programación\FreeBasic32\inc\win\basetsd.bi
 |   |   |   |  C:\Programación\FreeBasic32\inc\win\_mingw.bi
C:\Programación\FreeBasic32\inc\win\_mingw.bi(23) error 4: Duplicated definition, __STRINGIFY in '#define __STRINGIFY(x) #x'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(24) error 4: Duplicated definition, __MINGW64_STRINGIFY in '#define __MINGW64_STRINGIFY(x) __STRINGIFY(x)'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(38) error 4: Duplicated definition, __MINGW_IMP_SYMBOL in '#define __MINGW_IMP_SYMBOL(sym) _imp__##sym'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(39) error 4: Duplicated definition, __MINGW_IMP_LSYMBOL in '#define __MINGW_IMP_LSYMBOL(sym) __imp__##sym'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(41) error 4: Duplicated definition, __MINGW_USYMBOL in '#define __MINGW_LSYMBOL(sym) sym'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(46) error 4: Duplicated definition, __MSABI_LONG in '#define __MSABI_LONG(x) x##l'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(78) error 4: Duplicated definition, _CRT_INSECURE_DEPRECATE_MEMORY in '#define _CRT_INSECURE_DEPRECATE_MEMORY(_Replacement)'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(79) error 4: Duplicated definition, _CRT_INSECURE_DEPRECATE_GLOBALS in '#define _CRT_INSECURE_DEPRECATE_GLOBALS(_Replacement)'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(81) error 4: Duplicated definition, _CRT_OBSOLETE in '#define _CRT_OBSOLETE(_NewItem)'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(87) error 4: Duplicated definition in 'declare function __mingw_get_crt_info() as const zstring ptr'
C:\Programación\FreeBasic32\inc\win\_mingw.bi(87) error 132: Too many errors, exiting
Looks like the #pragma once and #include once directives are being ignored and the compiler tries to parse _mingw.bi twice.
Regardin WinFBE and other executables of some of my examples, they don't scale according the DPI setting and run at 96 DPI.
PowerBasic runs fine.
« Last Edit: April 26, 2018, 09:35:16 AM by José Roca »
Re: Problems with Windows 10
« Reply #1 on: April 26, 2018, 09:07:48 AM »
Hi José, what you describe seems super strange. I have been using Windows 10 since it was released. Never had any problems with it. It runs even better than Windows 7. I haven't noticed any scaling issues either. FireFly looks ugly on my new system but WinFBE looks perfect. Here are my specs:
Dell XPS, 16 gig RAM, i7-7700HQ @ 2.80GHz (64-bit Win10)
I am running a 3840 x 2160 screen at 350% scaling.
« Reply #2 on: April 26, 2018, 10:00:33 AM »
And the biggest problem is that I can't investigate because I can't compile.
Now you know why I have been so insistent about the importance of writing DPI aware applications. When running virtualized at such scaling, controls like check boxes a radio buttons look particullary horrible.
Johan Klassen
« Reply #3 on: April 26, 2018, 10:47:48 AM »
is C:\Programación equivalent to C:\Program Files? if so it could be a permissions problem
« Reply #4 on: April 26, 2018, 11:28:46 AM »
No, it happens that apparently FreeBasic does not like Spanish accents. After renaming the folder to "Programs", it works fine.
Now I have to investigate why it does not scale.
« Reply #5 on: April 26, 2018, 02:13:38 PM »
To solve the second problem, I have changed this line in CWindow.inc
IF AfxUseDpiScaling = 0 THEN this.DPI = 96 ELSE this.DPI = -1
to
IF AfxIsProcessDpiAware = FALSE THEN this.DPI = 96 ELSE this.DPI = -1
AfxUseDpiScaling queries the registry entry "Software\Microsoft\Windows\DWM" for the value of "UseDpiScaling", but this value is not present in my registry. I think that I used it in the times of Windows XP, where you could use large font but did not support the IsProcessAware function. Workarounds sometimes end biting you.
I have noticed that with Windows 10 you can change the DPI on the fly and Windows resizes the window and controls Cool!
@Paul,
I'm attaching the modified CWindow.inc file to allow you to test if it work with your editor.
« Reply #6 on: April 26, 2018, 04:38:47 PM »
@Paul,
Thanks! I have tried it wil both a 32 and 64 recompile of the editor and both seem to work okay. I haven't noticed any problems but if I do I will be sure to let you know.
« Reply #7 on: April 26, 2018, 04:42:46 PM »
On my system, that Registry entry existed and was set to true so of course I never noticed any issues. Thanks for fixing the issue so that it will now work on all modern versions of Windows.
« Reply #8 on: April 26, 2018, 05:15:19 PM »
Great. I have recompiled your editor and I can work with FreeBasic again.
