Author Topic: UDT's in Arrays  (Read 1819 times)
UDT's in Arrays
« on: May 13, 2018, 03:24:49 PM »
I know everyone is now mostly busy with Freebasic, but if you could still help ona powerbasic question i will appreciate it.
I need to create an Array of 50 items. I have done this by loading the list of items from a file in a function in a module.
I first declared a UDt like:
Type Tracker
    TPrefix As String * 2
    TText   As String * 16
    Used    As Integer
End Type
Type Virtualtracker
     Mytracker (1 To 50)  As Tracker
End Type
In the module i can easily add data to the array and i tested it, the information is loaded correctly:
im VArray As Virtualtracker
'-clear all
For t& = 1 To 50
 Varray.mytracker(t&).Tprefix = ""
 Varray.mytracker(t&).TText   = ""
 Varray.mytracker(t&).used    = 0
Next t&
Myfile& = FreeFile
Dim Xtracker As tracker
Open "Trackers.TRX" For Random As #myfile& Len = Len(Xtracker)
     For t& = 1 To 50
      Get #myfile&,t&, Xtracker
      If Xtracker.used = 1 Then GoSub FFFOUNDER
     Next t&
Close #myfile&
Exit Function
FFFounder:
    Varray.mytracker(t&).Tprefix = Xtracker.Tprefix
    Varray.mytracker(t&).TText   = Xtracker.Ttext
    Varray.mytracker(t&).used    = 1
Return
Exit Function
I want to other functions across the program to be able to read this list of 50 items from the UDT, but i can only access the data while i am in the module.
Any attempt to access the UDT from another function returns no data. I assume this has to be a issue one has to solve with a POINTER.
I need the speed of the in-memory array.
Any ideas would be welcome if you can figure out what i am trying to say....  :)
Re: UDT's in Arrays
« Reply #1 on: May 13, 2018, 07:33:07 PM »
Looks like you need to dim you Varray as GLOBAL
GLOBAL Varray() AS VirtualTracker
I guess that seems right? Hard to tell from my first look at your code.
David Kenny
  • Windows 7 & 10
Re: UDT's in Arrays
« Reply #2 on: May 13, 2018, 08:56:49 PM »
I think Paul has it right, but wanted to add that the global declaration will need to be outside any sub or function.
Re: UDT's in Arrays
« Reply #3 on: May 14, 2018, 02:13:03 AM »
Hi ALL
Nope, that doesnt help either.
I will try something else, 50 items isnt going to cause of much of a speed problem.
I will just load the process in the specific form and not bother with all this nested UDT's. That seem to be a problem here.
Thanks for the help guys.
_Peter
Eros Olmi
  • Little Newbie
    • www.thinbasic.com
Re: UDT's in Arrays
« Reply #4 on: May 16, 2018, 02:14:41 PM »
In your code it seems you are defining variable inside a function. That is a local, variable that is destroyed when function exit.
Suggested GLOBAL declaration should work and variable be seen across your modules as far as:
  • declared outside any function/sub
  • declared in a module that is loaded before the global variable is used
« Last Edit: May 16, 2018, 04:15:18 PM by Eros Olmi »
Re: UDT's in Arrays
« Reply #5 on: May 16, 2018, 03:08:21 PM »
Hi all
Thanks a million. Will Go give it a try and let you know if i got it working.
-Pete
