Author Topic: Getclientrect  (Read 1650 times)
Getclientrect
« on: May 20, 2018, 01:42:22 PM »
hi Guys
An old calculation is eluding me.
If i need to set a picturebox centre of a form during form resize how do i go about it again?
I remember it was Getclientrect of the main from and the same with the picturebox, but I cannot find that darn example on how to proceed from there!
_Regards, Pete
Pierre Bellisle
Re: Getclientrect
« Reply #1 on: May 21, 2018, 01:05:01 AM »
Hey Petrus,
WM_SIZE is your friend...
#Define JumpCmd "<S howInfo>"
#Define JumpCompiler "<D:\Free\32\fbc.exe>"
#Define JumpCompilerCmd "<-s gui -w pedantic "D:\Free\bas\~~Default.rc">"
#Print Control resize
#Print Coded on FreeBASIC 1.05.0
#Ifdef __FB_64BIT__
  #Print  64bit compiler used
#Else
  #Print  32bit compiler used
#EndIf
#Define unicode
#Include Once "windows.bi"
#Include Once "win\shellapi.bi" 'Extrac icon
#Define AppName    "Control resize"
Const ButtonExit = 101
Const Static01   = 201
Dim Shared As HINSTANCE hInstance : hInstance = GetModuleHandle(NULL)
Function WndProc(ByVal hWnd As HWND, ByVal uMsg As UINT, ByVal wParam As WPARAM, ByVal lParam As LPARAM) As Integer
 Static hFont       As HFONT
 Static hStatic     As HWND
 Static hButtonExit As HWND
 Select Case uMsg
   Case WM_CREATE
     Function = 0
     'Get Windows default font - - - - - - - - - - - - - - - - - - - - - - - -
     Dim As NONCLIENTMETRICS NotClientMetrics : NotClientMetrics.cbSize = SizeOf(NONCLIENTMETRICS)
     SystemParametersInfo(SPI_GETNONCLIENTMETRICS, NotClientMetrics.cbSize, @NotClientMetrics, 0)
     hFont = CreateFontIndirect(@NotClientMetrics.lfMessageFont)
     'Create a static control
     hStatic      = CreateWindowEx(WS_EX_CLIENTEDGE , "Static", "S t a t i c", _
                                   WS_CHILD Or WS_VISIBLE Or SS_CENTER Or WS_TABSTOP Or _
                                   SS_NOTIFY Or BS_TEXT Or SS_CENTERIMAGE, _
                                   50, 25, 200, 30, _
                                   hWnd, Cast(HMENU, ButtonExit), _
                                   hInstance, NULL)
     SendMessage(hStatic, WM_SETFONT, Cast(WPARAM, hFont), TRUE)
     'Create exit button
     hButtonExit  = CreateWindowEx(0, "Button", "E&xit", _
                                   WS_CHILD Or WS_VISIBLE Or BS_CENTER Or WS_TABSTOP Or _
                                   BS_NOTIFY Or BS_TEXT Or BS_VCENTER, _
                                   110, 70, 80, 30, _
                                   hInstance, NULL)
     SendMessage(hButtonExit, WM_SETFONT, Cast(WPARAM, hFont), TRUE)
    Case WM_COMMAND
     Select Case LoWord(wParam)
        Case ButtonExit
          If HiWord(wParam) = BN_CLICKED Then
            PostMessage(hWnd, WM_CLOSE, 0, 0)
            Exit Function
          EndIf
   Case WM_SIZE
     If wParam <> SIZE_MINIMIZED Then
       Dim As LONG SizeX = LOWORD(LPARAM)
       Dim As LONG SizeY = HIWORD(LPARAM)
       MoveWindow(hStatic, 50, 25, SizeX - 100, SizeY - 80, TRUE)
       MoveWindow(hButtonExit, SizeX / 2 - 50, SizeY - 40, 110, 30, TRUE)
     End IF
   Case WM_DESTROY
     DeleteObject(hFont)
     PostQuitMessage(0)
     Exit Function
 Function = DefWindowProc(hWnd, uMsg, wParam, lParam)
Function WinMain(ByVal hInstance As HINSTANCE, ByVal hPrevInst As HINSTANCE, _
                 ByVal CmdLine As WString Ptr, ByVal CmdShow As Integer) As UINT
 Dim WinClass   As WNDCLASS
 Dim wMsg       As MSG
 Dim hWnd       As HWND
 Dim hIco       As HICON
 Dim WindowSize As SIZEL
 Dim wsAppName  As WString * 128
 wsAppName              = AppName & " - " & SizeOf(UInteger) * 8
 WindowSize.cx          = 300
 WindowSize.cy          = 150
 hIco                   = ExtractIcon(hInstance, "Shell32.dll", 80)
 WinClass.style         = CS_HREDRAW Or CS_VREDRAW
 WinClass.lpfnWndProc   = ProcPtr(WndProc)
 WinClass.cbClsExtra    = 0
 WinClass.cbWndExtra    = 0
 WinClass.hInstance     = hInstance
 WinClass.hIcon         = hIco
 WinClass.hCursor       = LoadCursor(NULL, IDC_ARROW)
 WinClass.hbrBackground = Cast(HGDIOBJ, COLOR_BTNFACE + 1) 'Default color
 WinClass.lpszMenuName  = NULL
 WinClass.lpszClassName = @wsAppName
 If (RegisterClass(@WinClass)) Then
   hWnd = CreateWindowEx(WS_EX_WINDOWEDGE, _
                         wsAppName, wsAppName, _
                         WS_OVERLAPPED OR WS_CLIPCHILDREN Or WS_DLGFRAME Or WS_BORDER Or _
                         WS_VISIBLE Or WS_CAPTION Or WS_MINIMIZEBOX Or WS_SIZEBOX Or WS_SYSMENU , _
                         (GetSystemMetrics(SM_CXSCREEN) - WindowSize.cx) / 2, _ 'PosH
                         (GetSystemMetrics(SM_CYSCREEN) - WindowSize.cy) / 2, _ 'PosV
                         WindowSize.cx, WindowSize.cy, _ 'Width, height
                         NULL, NULL, hInstance, NULL)
   ShowWindow(hWnd, SW_SHOW)
   UpdateWindow(hWnd)
   While GetMessage(@wMsg, ByVal NULL, 0, 0) > 0
     If IsDialogMessage(hWnd, @wMsg) = 0 Then
       TranslateMessage(@wMsg)
       DispatchMessage(@wMsg)
   Wend
  DestroyIcon(hIco)
  Function = wMsg.message
End WinMain(hInstance, NULL, Command(), SW_NORMAL) 'Call main() and return the error code to the OS
Pierre Bellisle
Re: Getclientrect
« Reply #2 on: May 21, 2018, 01:25:47 AM »
I guess that some PowerBASIC code will be more appropriate...
#COMPILE EXE '#Win 9.07#
#DIM ALL
#REGISTER NONE
#INCLUDE "Win32Api.inc"
#RESOURCE "D:\Basic\Bas\~~PbrDefault00.pbr"
GLOBAL hDlg AS DWORD
$AppName  = "Control resize"
%Static01 = 101
%Button01 = 201
CALLBACK FUNCTION DlgProc
 SELECT CASE CBMSG
   CASE %WM_COMMAND
     SELECT CASE CBCTL
       CASE %Button01
         IF CBCTLMSG = %BN_CLICKED OR CBCTLMSG = 1 THEN
           DIALOG END hDlg
   CASE %WM_SIZE 'Dialog size have changed
     IF CBWPARAM <> %SIZE_MINIMIZED THEN
       LOCAL ClientSizeX AS LONG
       LOCAL ClientSizeY AS LONG
       ClientSizeX = LO(WORD, CBLPARAM)
       ClientSizeY = HI(WORD, CBLPARAM)
       MoveWindow(GetDlgItem(hDlg, %Static01), 25, 10, ClientSizeX - 50, ClientSizeY - 55, %TRUE)
       MoveWindow(GetDlgItem(hDlg, %Button01), ClientSizeX / 2 - 41, ClientSizeY - 35, 85, 30, %TRUE)
       InvalidateRect(hDlg, BYVAL %NULL, %TRUE)
FUNCTION PBMAIN()
 LOCAL hIcon AS DWORD
 DIALOG FONT "Segoe UI", 9
 DIALOG NEW %HWND_DESKTOP, $AppName, , , 200, 65, _
 %WS_CAPTION OR %WS_MINIMIZEBOX OR %WS_MAXIMIZEBOX OR %WS_SIZEBOX OR %WS_SYSMENU, 0 TO hDlg
 SetClassLong(hDlg, %GCL_HICON, LoadIcon(GetModuleHandle(BYVAL 0), BYVAL 101)) 'Icon with numeric descriptor from rc file
 hIcon = ExtractIcon(GETMODULEHANDLE(""), "%SystemRoot%\system32\PowrProf.dll", 1)
 SetClassLong(hDlg, %GCL_HICONSM, hIcon)
 SetClassLong(hDlg, %GCL_HICON, hIcon)
 CONTROL ADD LABEL, hDlg, %Static01, "Resize control (Yours to do pixel vs DU)", _
 25, 5, 150, 30, %SS_CENTER OR %SS_CENTERIMAGE OR %SS_NOTIFY, %WS_EX_CLIENTEDGE
 CONTROL ADD BUTTON, hDlg, %Button01, "E&xit", 82, 45, 35, 15
 DIALOG SHOW MODAL hDlg CALL DlgProc
 DestroyIcon(hIcon)
Re: Getclientrect
« Reply #3 on: May 21, 2018, 08:33:04 AM »
Great Stuff Pierre!!!
I should really keep better records of my examples!!
Thanks for the help man, much appreciated!
-Pete
