Author Topic: AfxGetWindowLocation  (Read 1026 times)
« on: June 20, 2018, 11:09:36 AM »
Hi Jose, curious as to why you decided to use pointers for the incoming nLeft and nTop parameters rather than using ByRef which would be more "BASIC-like"?
' Gets the location of the top left corner of the window, in pixels.
' The location is relative to the upper-left corner of the client area in the parent window.
PRIVATE SUB AfxGetWindowLocation (BYVAL hwnd AS HWND, BYVAL nLeft AS LONG PTR, BYVAL nTop AS LONG PTR)
   DIM rc AS RECT
   ' // Get the dimensions of the window
   GetWindowRect(hwnd, @rc)
   ' // Convert the coordinates to be relative to the parent
   MapWindowPoints(HWND_DESKTOP, GetParent(hwnd), CAST(POINT PTR, @rc), 2)
   ' // Return the left and top values
   *nLeft = rc.Left
   *nTop = rc.Top
Re: AfxGetWindowLocation
« Reply #1 on: June 20, 2018, 12:04:57 PM »
Probably it was one of the first that I wrote and I was still trying to follow the syntax used by the FB includes. I can change it if you want.
« Reply #2 on: June 20, 2018, 05:07:31 PM »
I'd vote for changing it because it seems out of place with the rest of your wrappers.
« Reply #3 on: June 20, 2018, 06:17:29 PM »
Changed to:
PRIVATE SUB AfxGetWindowLocation (BYVAL hwnd AS HWND, BYREF nLeft AS LONG, BYREF nTop AS LONG)
   DIM rc AS RECT
   nLeft = rc.Left
   nTop = rc.Top
