Author Topic: CWSTR and pointer arithmetic (zero vs one based)  (Read 1428 times)
« on: July 04, 2018, 12:08:13 PM »
CWSTR seems to handle pointer arithmetic based on one based rather than zero based?
#Define UNICODE
#Define _WIN32_WINNT &h0602
#Include Once "windows.bi"
#Include Once "Afx\AfxStr.inc"
Using Afx
dim as CWSTR wszText = "This is my text."
' Use pointer indexing to get each character (zero based - incorrect)
for i as long = 0 to len(wszText) - 1
   ? wszText[i], wchr(wszText[i])
' Use pointer indexing to get each character (one based - correct)
for i as long = 1 to len(wszText)
' Shouldn't pointer indexing be ZERO based in order to stay consistent
' with the FB language?
? "Done"
Sleep
Re: CWSTR and pointer arithmetic (zero vs one based)
« Reply #1 on: July 04, 2018, 01:02:19 PM »
I think that it was thought as an alternative syntax for Char, that is one based, but you're right.
Changed to:
' Returns the corresponding ASCII or Unicode integer representation of the character at
' the zero-based position specified by the nIndex parameter (0 for the first character,
' 1 for the second, etc.), e.g. value = cws[1]. ' Can't be used to change a value.
PRIVATE OPERATOR CWStr.[] (BYVAL nIndex AS UINT) AS USHORT
   IF nIndex < 0 OR nIndex > (m_BufferLen \ 2) - 1 THEN EXIT OPERATOR
   ' Get the numeric character code at position nIndex
   OPERATOR = PEEK(USHORT, m_pBuffer + (nIndex * 2))
END OPERATOR
« Reply #2 on: July 04, 2018, 01:21:51 PM »
Excellent - works perfectly now.
« Reply #3 on: July 05, 2018, 12:10:21 AM »
To change a value using pointer arithmetic we need to use an intermediate pointer variable:
DIM AS CWSTR wszText = "This is my text."
DIM p AS WSTRING PTR = *wszText
p[1] = ASC("x")
or use casting:
(*wszText)[1] = ASC("x")
--or--
CAST(WSTRING PTR, *wszText)[1] = ASC("x")
When using the [] operator this way, there is not range checking. Therefore, make sure that the string is not empty and that the index does not exceed the range "[0, Len(wszText) - 1]". Outside this range, results are undefined.
« Last Edit: July 05, 2018, 12:41:10 AM by Josť Roca »
