Author Topic: CiniFile  (Read 915 times)
CiniFile
« on: August 13, 2018, 11:54:02 PM »
Hi Josť,
Dim as CiniFile ini = "C:\BootTime\boottime.ini"
Dim as CWSTR s = Trim( frmMain.txtNotes.Text )
Dim as Boolean boo1 = ini.WriteValue( ct.Format("%Y-%m-%d"), Str(Time) & ".2", Space( 1 ) & s )
Results in the following Error:C:\WinFBE_Suite\Sample_Projects\BootTimeTest\modMain.bas(81) error 98: Ambiguous call to overloaded function, WRITEVALUE() in 'dim as Boolean boo1 = ini.WriteValue( ct.Format("%Y-%m-%d"), Str(Time) & ".2", Space( 1 ) & s )'
Declare s as a String and the result is no error.
Re: CiniFile
« Reply #1 on: August 14, 2018, 10:11:13 AM »
Sometimes the "&" string concatenation causes issues with combining FB and CWSTR variables. Change it to the following and it should work:
Space( 1 ) + s
(or more technically correct)
WSpace( 1 ) + s
Re: CiniFile
« Reply #2 on: August 14, 2018, 10:51:13 AM »
The behaviour of the & operator, tailored to please nostalgics of VB6, can cause problems sometimes because it supports to concatenate numbers with strings. As CWSTR is not a string, but a pointer to a class, the compiler sometimes fails to ascertain if it has to convert the value of the pointer to a string or call the cast operator of the class.
