Author Topic: What Do You Think FireFly SDK for PowerBasic Open Source Code  (Read 1686 times)
Stephane Fonteyne
  • PowerBasic Developer with FF3 & Windows XP
« on: August 18, 2018, 08:01:02 AM »
It is possible for interested developers here to the program FireFly SDK Designer for Powerbasic, improving and expanding with new capabilities and features to the completely open source.
So all source code to release the application (bass, Inc., pbr/rc, pblib, sll, DLLs)
That would be an added value to your business and other developers that offer the product than under GNU licenses
Only for licences PowerBasic Developers
Kind regards
Stephane
Stephane Fonteyne
Ba. Elektronica - ICT
GSM : +32-xxxxxxxxxx
Re: What Do You Think FireFly SDK for PowerBasic Open Source Code
« Reply #1 on: August 18, 2018, 09:05:24 AM »
The FireFly Visual Designer will never be open source code.
Stephane Fonteyne
« Reply #2 on: August 19, 2018, 06:34:53 AM »
Oke I understand that FireFly SDK Designer for PowerBasic but whynot support that with new updates and upgrades because the licences user have paid for this product and will support in the form of bug fixes, updates, upgrades.
Kind regards
Stephane
Stephane Fonteyne
Jean-pierre Leroy
« Reply #3 on: August 19, 2018, 11:08:47 AM »
Hi Stephane, I use FireFly 3 with PowerBASIC since october 2009 (almost 9 years) without any particular issue; FireFly is very reliable. It's my favorite IDE and GUI designer, for Windows 32 bits applications. If you encounter any problem, please post-it in this forum; I'm pretty sure that Paul (or other FF users) will find a fix or a workaround for you  :)
Kind regards,
Jean-Pierre
