WinFBE - WinFBE.ini - Observation
Started by SeaVipe, September 06, 2018, 03:47:11 PM
    DIM pTxtStm AS CTextStream
    ' // Open file as a text stream
    DIM cbsFile AS CBSTR = "C:\WinFBE_Suite\Settings\WinFBE.ini"
    pTxtStm.Open( cbsFile, IOMode_ForReading )
    ' // Read the file sequentially
    Dim as byte bLine = 0
    Print "Begin }---------------------------------------------"
    Do Until bLine >= 10 Or pTxtStm.EOS
       bLine += 1
       DIM cbsText AS CBSTR = pTxtStm.ReadLine
       PRINT bLine; ">"; cbsText; "<"
    Loop
    Print
    Print
    Print "For reference, here are the 10 lines cut and paste from the ini file with line numbers added:"
    PRINT "1  '  WINFBE CONFIGURATION"
    Print "2"
    PRINT "3  WinFBEversion=1.7.9"
    Print "4"
    PRINT "5  [Editor]"
    PRINT "6  AskExit=0"
    PRINT "7  HideToolbar=0"
    PRINT "8  HideStatusbar=0"
    PRINT "9  MultipleInstances=1"
    PRINT "10 CompileAutosave=1"
    Print "End }-----------------------------------------------"
    pTxtStm.Close
The output is shown in the attached image.
I can open WinFBE.ini in Notepad++ (which is where I cut and paste for reference.)
BTW, I got the version number from changes.txt using the same code but with a different file name.
#1
The file is unicode. Therefore, use pTxtStm.OpenUnicode instead of pTxtStm.Open.
You can also use pTxtStm.OpenForInputW(cbsFile).
