Will do...
Cut'Paste
'#CONSOLE ON
#define UNICODE
#INCLUDE ONCE "Afx/CSQLite3.inc"
USING Afx
' // Optional: Specify the DLL path and/or name
' // This allows to use a DLL with a different name that sqlite3.dll,
' // located anywhere, avoiding the neeed to have multiple copies of the same dll.
DIM pSql AS CSQLite = "sqlite3_64.dll"
print pSql.m_hLib
' // Create a new database
' // I'm deleting and recreating the database for testing purposes
DIM cwsDbName AS CWSTR = AfxGetExePathName & "Test.sdb"
IF AfxFileExists(cwsDbName) THEN AfxDeleteFile(cwsDbName)
DIM pDbc AS CSQLiteDb = cwsDbName
' // Create a table
IF pDbc.Exec("CREATE TABLE t (xyz text)") <> SQLITE_DONE THEN
AfxMsg "Unable to create the table"
END
' // Insert rows
IF pDbc.Exec("INSERT INTO t (xyz) VALUES ('fruit')") <> SQLITE_DONE THEN AfxMsg "INSERT failed"
IF pDbc.Exec("INSERT INTO t (xyz) VALUES ('fish')") <> SQLITE_DONE THEN AfxMsg "INSERT failed"
' // Prepare a query
DIM pStmt AS CSqliteStmt = pDbc.Prepare("SELECT * FROM t")
PRINT "Column count: ", pStmt.ColumnCount
' // Read the column names and values
DO
' // Fetch rows of the result set
IF pStmt.GetRow = SQLITE_DONE THEN EXIT DO
' // Read the columns and values
FOR i AS LONG = 0 TO pStmt.ColumnCount- 1
PRINT pStmt.ColumnName(i)
PRINT pStmt.ColumnText(i)
LOOP
PRINT
PRINT "Press any key..."
SLEEP
