Author Topic: Markup  (Read 667 times)
David Kenny
  • Windows 7 & 10
Markup
« on: November 24, 2018, 03:44:53 PM »
You mention using Markup in a recent post.  Can you be more specific? It's too generic a term to get good search results. I did search the forum in case you mentioned it before. Only found two other hits in much older threads.
David
Re: Markup
« Reply #1 on: November 24, 2018, 10:31:57 PM »
I am using (and Jose is also) GitHub Markdown syntax to create simple ascii text files for our Help. I then use Pandoc to convert the Markdown files to HTML and then display them in the embedded webbrowser in the help viewer.
Here is the GitHub Markdown syntax:  https://help.github.com/categories/writing-on-github/
David Kenny
  • Windows 7 & 10
Re: Markup
« Reply #2 on: November 26, 2018, 11:33:45 PM »
You got me...
I should have the next update out as early as tomorrow. I just finished the documentation conversion to markup.
(Markup is sooooooo easy to use and it produces great looking documentation).
I only spent a few minutes searching for it.  Thanks for the info.
