Hi Johan Klassen (aka srvaldez)
Re:
https://www.freebasic.net/forum/viewtopic.php?f=7&t=27198You can use:
FUNCTION AfxRound (BYVAL dblValue AS DOUBLE, BYVAL numDigits AS LONG) AS DOUBLE
IF numDigits < 1 THEN RETURN dblValue
IF numDigits > 9 THEN numDigits = 9
DIM nMult AS LONG = 10 ^ numDigits
FUNCTION = FIX((nMult * dblValue + (SGN(dblValue)) * .5)) / nMult
FUNCTION AfxRoundToStr (BYVAL dblValue AS DOUBLE, BYVAL numDigits AS LONG) AS STRING
IF numDigits < 1 THEN RETURN STR(dblValue)
dblValue = FIX((nMult * dblValue + (SGN(dblValue)) * .5)) / nMult
DIM strNum AS STRING = STR(dblValue)
DIM p AS LONG = INSTRREV(strNum, ".")
DIM nLen AS LONG = LEN(MID(strNum, p + 1))
IF p THEN
IF nLen < numDigits THEN strNum += STRING(numDigits - nLen, "0")
strNum += "." & STRING(numDigits, "0")
FUNCTION = strNum
Use as you wish. No restrictions
