https://github.com/PaulSquires/WinFBE/releasesVersion 1.9.0 (January 22, 2019)
- Added: Goto Header file (.bi) (Ctrl+Shift+H). Option found in Search / Code Navigation.
- Added: Goto Code file (.bas, .inc) (Ctrl+Shift+C). Option found in Search / Code Navigation.
- Added: Goto Main file (.bas) (Ctrl+Shift+M). Option found in Search / Code Navigation.
- Added: Goto Resource file (.rc) (Ctrl+Shift+R). Option found in Search / Code Navigation.
- Added: Explorer treeview subnodes to hold Header, Resource, Main, Module, Normal files (for Projects only).
- Added: User Snippets (insert user defined code snippets).
- Added: Image Manager.
- Added: Image related properties for the Button control and Form.
- Added: PictureBox control.
- Added: A search textbox added to Function List (filters the function list based on the search term).
- Added: Creating a New Project will automatically add a default empty .bas main file (unsaved) to the project for convenience.
- Added: Environment Option to Check for update at startup (once per day).
- Added: Check for Updates added to Help menu.
- Added: Next Tab, Previous Tab, Close Tab to the Search menu (Tab Navigation submenu).
- Added: Next Function (Ctrl+PgDn), Previous Function (Ctrl+PgUp) to the Search menu.
- Added: New About form replaces the generic messagebox.
- Added: Pressing F6 or selecting "Sub/Function Definition" will open any #Include file on the current editing line.
- Added: Additional info outputted to "Compile Log File" in Output window (Full compiler command line, filesize, compile time, error/warning count).
- Added: "Open Templates... (Ctrl+T)" in the "File" menu. Previously, templates could only be accessed from the Toolbar.
- Added: Sub/Function Definition (F6) will now work on Sub/Functions that are part of TYPE classes.
- Changed: You must now hold down the SHIFT key to drag and drop tabs in the top tab control to reorder any open document tabs.
- Changed: Updated FreeBasic Compiler to November 22, 2018 Nightly Build.
- Changed: Lots of internal code refractoring. Many efficiencies found with regards to loading files/projects, saving, and displaying files. More internal code cleanup to occur in the next few future releases.
- Changed: Removed loading of multiple projects into WinFBE at the same time.
- Changed: When project is active, "Open File" will add file to project open it. "Add Files to Project" will only add the files to the Project but not display it.
- Changed: Removed the option to display the successful compile results dialog. Result will now only show in the statusbar.
- Changed: Any missing non-English translation phrases will now use the English phrase rather than nothing at all.
- Changed: Moved "User Tools" from Options menu to "Tools" menu.
- Changed: File Open file types now have *.inc included in "Code files". "FB Include files" change to "Header files".
- Changed: Moved Bookmark menu entries to "Bookmarks" submenu of the "Search" menu.
- Changed: Removed the "Save Declares File" menu option as it is obsolete.
- Changed: Updated Spanish language translation file by José Roca.
- Changed: Updated German language translation file by Joerg Buckel.
- Changed: Updated Chinese language translation file by ganlinlao.
- Fixed: Modified English.lang file to compress by 58 entries. Other language files will need to be slightly modified by their respective authors.
- Fixed: Some issues with right-click menu on #Include line to display "Open <include filename>" when a project is open.
- Fixed: F3/Shift+F3 Find/Find Next accelerator tweaked slightly to ensure previously selected text gets searched.
- Fixed: Parsing of multiline characters where both /' and '/ appear on the same line.
- Fixed: Infinite loop when responding "No" to reload a currently loaded file that has been modified outside of WinFBE.
- Fixed: The search option for 'Sub/Function Definition (F6)" was not correctly finding SUBS (Functions worked okay).
- Fixed: Localization language editor in Environment Options / Localization not allowing editing (incorrect logic).
- Fixed: Graceful creation of a default WinFBE.ini config file should it be missing or corrupted.
- Fixed: The "Wait" cursor now correctly and consistently shows when loading a project, compiling code, or loading many files.
- Fixed: Occasional problem of resizing/dragging of Explorer panel would not stop after left mouse buttonup action.
- Fixed: No longer allow Read Only files to be edited. Statusbar message shows "Read Only".
