Sadly, I'm not a FireFly user, but still, here is the same Mutex & GW_HWNDNEXT approach I had in PowerBASIC...
#Define JumpCompiler "<D:\Free\64\fbc.exe>" 'Compiler to use "< = left delimiter, >" = right delimiter
#Define JumpCompilerCmd "<-s gui -w pedantic "D:\Free\bas\~~Default.rc">" 'Command line to send to compiler (gui or console)
#define UniCode
#Include Once "windows.bi"
#Include Once "win\shellapi.bi"
#Define AppName "Mutex demo"
#Define StaticInfo 101
#Define CrLf Chr(13, 10)
#Define dwMutex 1901310955 '[YYMMDDHHMM] - 10 digits - Max is 4,294,967,295, I use current time
Dim Shared As HINSTANCE hInstance : hInstance = GetModuleHandle(NULL)
Function WndProc(ByVal hWnd As HWND, ByVal uMsg As UINT, ByVal wParam As WPARAM, ByVal lParam As LPARAM) As Integer
Dim hStaticInfo As HWND
Static hWindowDefaultFont As HFONT
Function = 0
Select Case (uMsg)
Case WM_CREATE
Dim As NONCLIENTMETRICS NotClientMetrics
NotClientMetrics.cbSize = SizeOf(NONCLIENTMETRICS)
SystemParametersInfo(SPI_GETNONCLIENTMETRICS, NotClientMetrics.cbSize, @NotClientMetrics, 0)
hWindowDefaultFont = CreateFontIndirect(@NotClientMetrics.lfMessageFont)
hStaticInfo = CreateWindowEx(0, "Static", "Try to run another self instance" & CRLF & "(Minimize me before)", _
WS_CHILD Or WS_VISIBLE Or SS_CENTER Or SS_NOTIFY, _
10, 30, 200, 30, _
hWnd, Cast(HMENU, StaticInfo), _
hInstance, NULL)
SendMessage(hStaticInfo, WM_SETFONT, Cast(UInteger, hWindowDefaultFont), TRUE)
Case WM_DESTROY
DeleteObject(hWindowDefaultFont) 'Clean up
PostQuitMessage(0) 'Ask message loop to end
Exit Function
Function = DefWindowProc(hWnd, uMsg, wParam, lParam)
Function WinMain(ByVal hInstance As HINSTANCE, ByVal hPrevInst As HINSTANCE, _
ByVal CmdLine As WString Ptr, ByVal CmdShow As Integer) As UINT
Dim WinClass As WNDCLASS
Dim wMsg As MSG
Dim hWnd As HWND
Dim hIco As HICON
Dim WindowSize As SIZEL
Dim wsAppName As WString * 128
wsAppName = AppName
WindowSize.cx = 230
WindowSize.cy = 120
hIco = ExtractIcon(GETMODULEHANDLE(""), "Shell32.dll", 294) 'o
WinClass.style = CS_HREDRAW Or CS_VREDRAW
WinClass.lpfnWndProc = ProcPtr(WndProc)
WinClass.cbClsExtra = 0
WinClass.cbWndExtra = 0
WinClass.hInstance = hInstance
WinClass.hIcon = hIco
WinClass.hCursor = LoadCursor(NULL, IDC_ARROW)
WinClass.hbrBackground = Cast(HGDIOBJ, COLOR_BTNFACE + 1) 'Default color
WinClass.lpszMenuName = NULL
WinClass.lpszClassName = @wsAppName
Dim hTry As HWND
Dim hMutex As HWND
Dim zMutex As ZString * 16
zMutex = "MyUniqueMutex" 'MaxStringLen is %MAX_PATH, no "\", case sensitive
hMutex = CreateMutex(ByVal NULL, 0, zMutex)
If GetLastError = ERROR_ALREADY_EXISTS Then
Beep()
'Optionnal: MessageBox(HWND_DESKTOP, AppName & " is already running!", AppName, MB_TOPMOST Or MB_OK)
hTry = GetForegroundWindow()
Do While hTry
If GetWindowLongPtr(hTry, GWLP_USERDATA) = dwMutex Then
If IsIconic(hTry) Then ShowWindow(hTry, SW_RESTORE) 'Unminimize exe
SetForegroundWindow(hTry)
Exit Do
hTry = GetWindow(hTry, GW_HWNDNEXT)
Loop
If hTry = 0 Then 'Can't find it!!!
MessageBox(HWND_DESKTOP, AppName & " is running hidden in background!", AppName, MB_TOPMOST Or MB_OK)
End IF
End
If (RegisterClass(@WinClass)) Then
hWnd = CreateWindowEx(WS_EX_WINDOWEDGE, _
wsAppName, wsAppName, _
WS_OVERLAPPED OR WS_CLIPCHILDREN Or WS_DLGFRAME Or WS_BORDER Or WS_VISIBLE Or WS_CAPTION Or _
WS_MAXIMIZEBOX Or WS_MINIMIZEBOX Or WS_SYSMENU , _
(GetSystemMetrics(SM_CXSCREEN) - WindowSize.cx) / 2, _ 'PosX
(GetSystemMetrics(SM_CYSCREEN) - WindowSize.cy) / 2, _ 'PosY
WindowSize.cx, WindowSize.cy, _ 'Width, height
NULL, NULL, hInstance, NULL)
SetWindowLongPtr(hWnd, GWLP_USERDATA, dwMutex) 'Set window mutex
ShowWindow(hWnd, SW_SHOW)
UpdateWindow(hWnd)
While GetMessage(@wMsg, ByVal NULL, 0, 0) > 0
If IsDialogMessage(hWnd, @wMsg) = 0 Then
TranslateMessage(@wMsg)
DispatchMessage(@wMsg)
Wend
DestroyIcon(hIco)
CloseHandle(hMutex)
Function = wMsg.message
End WinMain(hInstance, NULL, Command(), SW_NORMAL) 'Call main() and return the error code to the OS
