Author Topic: "Reset" property of the CSQLiteStmt Class  (Read 1648 times)
« on: March 11, 2019, 09:36:03 AM »
Hi Jose,
FYI - you don't have the link set for the "Reset" property of the CSQLiteStmt Class.
https://github.com/JoseRoca/WinFBX/blob/master/docs/Databases/CSQLite%20Class.md
When you scroll down to the description for "Reset" it looks like you did not finish modifying Reset based on a copy/paste of the previous "ReadOnly" property description.
I have to create a small application for my work and am going to use SQLite for the database. This should allow me to properly test you classes.
Thanks!
Re: "Reset" property of the CSQLiteStmt Class
« Reply #1 on: March 11, 2019, 11:09:08 AM »
Modified. Thanks for spotting it.
« Reply #2 on: March 11, 2019, 05:42:58 PM »
BTW Do you already have tested if the windowsx.bi file that comes with the latest version of the compiler works with your applications? I can't work with DirectShow without it.
« Reply #3 on: March 12, 2019, 11:06:54 AM »
I changed AfxCtl.inc to use:
   #include once "win/windowsx.bi"
I have not experienced any issues at this point. I think we can be safe to deprecate the "windowsxx.bi" file at this point.
Thanks!
« Reply #4 on: March 13, 2019, 08:55:41 AM »
Writing this application for work is allowing me to find usability issues with the visual designer. It is turning out to be a good exercise and should help accelerate the completion of the visual designer development....although... I am heading to Jamaica all next week :) :) :)]
