WinFBE visual designer question
Started by Patrick Beyltjens, April 24, 2019, 05:28:43 PM
Patrick Beyltjens
Hi,
Iam new in Free Basic.
I use WinFBE and visual designer to learn the first steps.
It works very smoothly.
I have 2 questions for the moment :
1) How can i use a timer in the visual designer code. I like too update the  time in a text controll every second or so.
2) How can i use a tooltip on a button.
Can someone give me an example
Thanks in advance
No problem... I am working on an example project for you. There is no built in Timer control but I will use Win32 api calls to create one. I will post the results here later.
This is what the Timer code will look like.
Form is named frmMain
Start button is named cmdStart
Stop button is named cmdStop
const IDT_TIMER = WM_USER + 100
sub TimerProc( byval hwnd    as HWND, _
               byval uMsg    as UINT, _
               byval TimerID as UINT ptr, _
               byval dwTime  as DWORD _
   frmMain.txtResults.Text = wstr( val(frmMain.txtResults.text) + 1 )
Function frmMain_cmdStart_Click( ByRef sender As wfxButton, ByRef e As EventArgs ) As LRESULT
   ' Reset the textbox counter
   frmMain.txtResults.Text = "0"
   ' Create a timer that fires every second (1000 ms).
   SetTimer( frmMain.hWindow, _              ' handle to main window
             IDT_TIMER, _                    ' timer identifier
             1000, _                         ' 1-second interval
             cast( TIMERPROC, @TimerProc) )  ' timer callback
   Function = 0
Function frmMain_cmdStop_Click( ByRef sender As wfxButton, ByRef e As EventArgs ) As LRESULT
   ' Kill the timer that was previously created.
   KillTimer( frmMain.hWindow, IDT_TIMER )
   Function = 0
Application.Run(frmMain)
Oh, yes, you also asked about Tooltips. Those are easier. Just look at Jose's AfxCtrl.inc file in the \Inc\Afx folder of your WinFBE Suite compiler install. There is a whole section of functions in that file that handle Tooltips. Here is code for adding a simple tooltip to the Start button in my previous example. I did it in the frmMain Load event.
   ' Create tooptip
   dim as HWND hToolTip = AfxAddTooltip( frmMain.cmdStart.hWindow, "This is the Start button.", false, false )
   Function = 0
Here is the AfxAddTooltip definition:
' Creates a tooltip for a control.
' Parameters:
' - hwnd      = Handle of the window or control
' - wszText   = Tooltip text
' - bBalloon  = Ballon tip (TRUE or FALSE)
' - bCentered = Centered (TRUE or FALSE)
' Return Value:
'   The handle of the tooltip control
PRIVATE FUNCTION AfxAddTooltip (BYVAL hwnd AS HWND, BYREF wszText AS CONST WSTRING = "", BYVAL bBalloon AS BOOLEAN = FALSE, BYVAL bCentered AS BOOLEAN = FALSE) AS HWND
Patrick Beyltjens
Thanks a lot for the examples Paul.
I just used the modified timer example. It works perfect now.
My problem was in the first parameter from the set_timer function.
Busy day, Paul? Less than an hour or so to answer a couple of questions with example code.That's pretty impressive!
Lol, the stars all aligned correctly tonight. :-)
