Author Topic: Old Email Post  (Read 1488 times)
Old Email Post
« on: May 12, 2019, 03:50:19 PM »
Hi All
After many years I revisited a post I never used.
Basically, because at the time i didn't understand anything of what was being said & I felt too dumb to say so....
I came across a reply from Josè:
I integrated Paul's class in my headers (CAfxStmpMail.inc) with minimal changes, such as changing the logic of the return value of the SendMail method, and documented it in the help file (WinApiHeaders.chm).
I thought i would give this a visit again, but is unable to find the .inc file nor the reference in the .chm file.
All i really need to achieve is NOT to send the email, but just like a MAILTO link that opens the default email client (99% chance of being MS Outlook), and insert the TO address and a topic. That is it.
I also checked out Paul's email class and it continues to give me "Outlook object cannot be created" error.
If anyone has a Quick and Dirty fix like last time with the button Issue, it would be greatly appreciated.
-Regards Peter
Ian Vincent
  • Little Newbie
Re: Old Email Post
« Reply #1 on: May 13, 2019, 12:38:28 AM »
Petrus, See attached (zipped) include.
If you open it and scroll all the way to the end, you will find an example of it's usage.
Ian
Re: Old Email Post
« Reply #2 on: May 13, 2019, 02:55:38 PM »
Thanks Ian.
I will look for a few examples here on the forum tonight.
Thanks for the file.
-Peter
