Author Topic: FF3 - ListView Text And Text Background Colouring  (Read 1551 times)
« on: July 15, 2019, 07:56:39 PM »
Does anyone know if a ListView control can have different coloured Text And Text Background based on Items?
The 3 below work properly but they set colours for the entire ListView control not individual Items like Rows or Cells:
    '' Text
    ListView_SetTextColor(HWND_FORM1_LISTVIEW1, CLR_NONE) ' Windows text colour.
    '' Grid
    ListView_SetTextBkColor(HWND_FORM1_LISTVIEW1, &HBCB772 )
    '' The BackGround, behind everything
    ListView_SetBkColor(HWND_FORM1_LISTVIEW1, &HD25FDC)
I've been on the Microsoft site looking into all the various ListView API commands but nothing looks as though it will do what I want.
(If not then I'll dig a bit deeper into James Klutho's GRD (very nice) which I've yet to figure out how to get onto a FF3 or WinFBE form.)
Thanks.
Re: FF3 - ListView Text And Text Background Colouring
« Reply #1 on: July 15, 2019, 08:17:28 PM »
No. Windows controls do what they do and, when you want something different, you have to make them owenerdraw and paint them by yourself.
« Reply #2 on: July 15, 2019, 08:27:50 PM »
Thanks José, I had a feeling that was going to be the answer. Time for a little research!
David Kenny
  • Windows 7 & 10
« Reply #3 on: July 16, 2019, 06:54:39 AM »
SeaVipe,
This might speed up your research.  Example code by Jean-pierre Leroy: https://www.planetsquires.com/protect/forum/index.php?topic=2026.msg16333#msg16333
Link in the top post.
David
« Reply #4 on: July 16, 2019, 03:05:40 PM »
Thank you, David, Jean-Pierre's code works great; just what I was looking for!
Clive
