Author Topic: AfxGetComboBoxText  (Read 946 times)
AfxGetComboBoxText
« on: August 19, 2019, 03:00:19 PM »
Hi Jose,
Looks like AfxGetComboBoxText is returning a trailing NULL character. You probably need to modify the last line of the function similar to how you handle AfxGetWindowText.
Current code in AfxCtl.inc:
' Gets a string from a list in a combo box.
' - hComboBox: A handle to the combobox.
' - nIndex: The zero-based index of the item.
PRIVATE FUNCTION AfxGetComboBoxText (BYVAL hComboBox AS HWND, BYVAL nIndex AS LONG) AS CWSTR
   DIM nLen AS LONG = SendMessageW(hComboBox, CB_GETLBTEXTLEN, nIndex, 0)
   DIM cwsText AS CWSTR = SPACE(nLen + 1)
   SendMessageW(hComboBox, CB_GETLBTEXT, nIndex, cast(LPARAM, *cwsText))
   RETURN cwsText
Maybe:
   RETURN cwsText
Should be:
  RETURN LEFT(**cwsText, LEN(cwsText) - 1)
Took me a while to find out why some of my Form files with ToolBars were not loading. Appears that the NULL was being inserted into the file causing the parsing on load to fail.
« Last Edit: August 19, 2019, 03:14:24 PM by Paul Squires »
Re: AfxGetComboBoxText
« Reply #1 on: August 19, 2019, 03:20:05 PM »
Done. Thanks for spotting it.
